- 9 Dec 2009
- Bristol
Hi motors
I'm after some more whitish xenon bulbs. My mx5 NC, as I understand it, has hid projector headlights, also known as xenons. I replaced the little sidelight bulbs with led which I use as daytime running lights, but when I turn on the dipped beam they look so yellow and old fashioned, compared to the whitish glow of the sidelights.
Can I have some recommendations for modern looking decent replacements?
I'm not looking for anything to burn out the retinas of oncoming traffic, and I want them to have a reputation for longevity because I think it's an arch liner out job to do the dipped bulbs in this car, though I'll check my Haynes manual for fitting instructions.
Anyway, suggestions will be much appreciated.
Edit: just been reading that xenons are usually good for 10 years, my car is 10 so that may explain the yellowness.
In terms of whiter bulbs I've found the Philips Whitevision bulbs can make halogens in projectors look 'almost' Xenons - certainly at a glance you wouldn't notice the difference. I used them in my last two Smart cars and my current MX5.
