Those hoping to use SAM with AMD 5 series and 6 Series Gfx Cards might have a problem
17 Sep 2007
Basically it might require you reinstalling windows and activating UEFI in BIOS as a lot of you will have installed using legacy MBR instead. If your Windows install was done in UEFI then hopefully your windows partition should then be set to GPT, and you should be OK. If you however installed in CSM compatibility mode. Then to use this new feature you will have to reinstall or convert windows partition to GPT and change BIOS setting as workaround.
This will most likely affect Nvidia offering also.
As posted by Egor
https://translate.googleusercontent...essen/&usg=ALkJrhix1uEhV7x0PyDNLoPqKTnzK3o7Rg
Who doesn't use UEFI bios these days?
I agree but some might have changed the bios setting and installed in capability mode. Or has hardware that isn't compatible with UEFI for example an add in legacy card (highly unlikely)
Thread probably just a warning to make sure they haven't changed the setting in BIOS away from UEFI.
