- 4 May 2009
- Edinburgh, UK
I have an EK 011 distro plate (the side-mount one) mounted in an 011 XL, and I'm using the Gigabyte SIV utility (on an X570 Aorus Pro ATX board).
The distro plate was connected to SYS_5_PUMP on the motherboard, and I had 3x fans connected to CPU_FAN, 3x fans connected to CPU_OPT, and 1 connected to SYS_FAN1.
I just recently replaced all my EK fans with Lian Li Unifans, which are connected to the Lian Li controller. The controller is set to PWM, using the CPU_OPT as a signal source, which can use the fluid temp (EC_TEMP1) as an input. The reasoning here being that the fluid is keeping the CPU & GPU cool, so if that temp starts to rise, the fans need to blow harder over the rads to cool things down.
The distro is connected to the CPU_FAN header.
This has achieved the goal, whereby the system overall is a whole lot quieter, since I don't have fans boosting on CPU temp fluctuations. Overall, the system and fluid temps are staying constant with the fluid around 6 deg over ambient, rising to 10 deg over ambient after 3hrs' gaming.
So far, so good, however...
I have the fan curve on the CPU (driving the fluid pump) set to 50% for CPU temps for up to 50 deg, rising to 100% by the time the CPU hits 60 deg. Firstly, should I worry about this? Is running the pump at 50% (which, actually, is 2000rpm, so is really 66%) bad for it?
Secondly, this is the result of some experimentation. Between 2200RPM and 2600RPM, the pump has a resonance that is a really unpleasant noise. Unfortunately, with the system as a whole being much quieter, the resonance is now driving me nuts.
So I'm looking to you for suggestions.
- Is it possible to mount the pump into the case differently, e.g. using some grommets or similar as dampers, in case the resonance is actually a case vibration?
- Should I just run the pump between 1000RPM & 2000RPM, avoiding the speed where the resonance happens?
- Should I RMA the distro plate to get another one?
- Or, more dramatically, but I would consider it, should I bin the distro plate and use a different pump/res combo?
