Tablet Ram
11 Oct 2009
Greater London
2gb certainly is small but it shouldn't cause the internet to slow down. I would consider going down the custom ROM route, they usually are better RAM usage/management wise especially compared to Samsung's skin.
11 Oct 2009
Greater London
It's basically like replacing Windows on your PC with a different OS. In this case, it's just moving to a different flavour of Android. Bare in mind doing this will mean you will lose DRM (so no HD in Netflix for example) and potentially not passing SafetyNet (which is needed for things like banking apps), but if you don't need either of those things then it's worth trying out. You can find what custom ROMs are available for your device, as well as guides on how to install it here: https://forum.xda-developers.com/
