Oldest GPU to support 3440x1440?
17 May 2013
West Sussex, UK
Looking for the oldest/cheapest GPU that can support 3440x1440. Obviously won't be gaming.
Need something cheap to stick in there while I find a new GPU
I've stuck an old 9500GT in it and it loaded into windows. I uninstalled AMD stuff and restarted the PC.
On restart it detected the cars and installed drivers automatically. Since then I've go no display. I'm pretty certain the PC is booted.
I assumed the resolution isn't supported, or the card is too old for the system perhaps?
Might be worth a bios update to your motherboard usually if a video card is not recognised, windows will use compatibility drivers and run at a very low res
Your issue is more likely to be the oldest card that Windows will detect. I found out to my cost that the 7850 and a 750ti aren't detected by a modern, clean windows install.
You can get around by installing 1509 or a similar era OS, but it's a pain.
I don't want to muck about with windows. It was a clean install last month. Perhaps I'll just have to wait until I find a card
i currently have a gtx 760 and recently did a clean install of win10 and it detected my gpu with no issue, thats crazy it wouldnt detected your 750ti
