- 20 Jun 2016
OUT OF STOCKcome on team RED where you at?!
just upgraded to an apex and new ram/cpu on route its time for round two.
CPU score is OK, you can improve it but for bench epeen only. Close all running apps / background processes etc and should raise the score a little. You will get higher frame rate with a 5900x etc (I'm changing mine out for one) but that's basically squeezing the rig for max fps.
OUT OF STOCK
OK I'll give that a go when I upgrade my CPU, the 5900x is next on my upgrade path I think. Just done a bit more overclocking and got a 20885 GPU score now, so it seems happy enough
It costs £3.5Was going to benchmark my old and new GPU but these look to be paid applications now, is that right? Or is there somewhere where its free?
Score 4211, GPU RX480 @1303/2000, GFX Score 4151, CPU Score 4592, CPU 6600k @4.4, Post No.0575, danlightbulb - Link Drivers 16.9.1
Just seen this thread, may as well slap this in;
Probably get another 100 or so points out of it if I push it.
For the scoreboard you need to post the results link.
