I'm using a very old PC that has many issues:
.i7 2600 CPU
.GTX 750 ti GPU
.8GB ddr3 (4 X 2GB)
.100GB SSD
.500GB HDD
I mainly use it for playing older titles and strategy games. I'm on a tight budget and can't justify spending much on gaming. I was planning on replacing the motherboard and power supply, as that's where I believe most of the problems come from. As far as I can tell from the tests I've been able to run, the CPU, GPU, drives and memory are all still fine. But I've learned that they no longer manufacture motherboards compatible with that CPU?
Can anyone tell me a way of getting hold of a new compatible motherboard for a reasonable price? Or even a decent refurbished one? Or is my only alternative to get a new CPU along with it? I might be able to stretch to that (as long as it was compatible with all the other old components), but it seems a shame to junk the only half decent part of the PC, even if it is ancient.
I suppose ultimately what I'm looking for is the cheapest/least hassle solution that allows me to play Crusader Kings without issues. Any advice greatly appreciated (or if you can direct me to anywhere more appropriate to ask this kind of thing.)
			.i7 2600 CPU
.GTX 750 ti GPU
.8GB ddr3 (4 X 2GB)
.100GB SSD
.500GB HDD
 looking for a few other bits that are lost in boxes after moving house anyway. if it turns up you can have it, better than sticking it into landfill or waiting 2 million years for rats to become sentient then get confused about the cultural and religious significance of an intel motherboard
 Thanks, if it does turn up that'd be great. Happy to give you the small amount I'll pay for an old board otherwise as some compensation for your time, on top of postage obvs.
