Online Gaming is shockingly slow and i dont understand why?
29 Nov 2020
Hi folks my son enjoys playing the game Flashing Lights online, however the in game lag is awful and to be honest with my spec of PC i cant understand why?, can anyone enlighten me ?. it would be much appreciated. Attached is a copy of my DXDiag file. Many Thanks
Operating System: Windows 10 Home 64-bit (10.0, Build 19042) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 08/06/12 09:44:07 Ver: 08.00.15 (type: BIOS)
Processor: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz (8 CPUs), ~2.8GHz
Memory: 24576MB RAM
Available OS Memory: 24568MB RAM
Page File: 4654MB used, 23880MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0546 64bit Unicode
24 May 2006
Surrey - UK
Is the system performing fine in other games with similar or higher requirements?
What GPU (Graphics card) is in the system?
OP
29 Nov 2020
GPU, I have an Nvidi GTX 750Ti. This is what the game recommends you have
  • MINIMUM:
    • OS: Windows 7/8/10 (64bit)
    • Processor: Intel Core i3 2GHz or equivalent
    • Memory: 4 GB RAM
    • Graphics: AMD R7 200 Series / NVidia 700 series with 1GB vram or above
    • DirectX: Version 11
    • Storage: 4 GB available space
Permabanned
23 Apr 2014
Hertfordshire
System requirements are quite low assuming I have the right game on Steam and its got very positive reviews so probably not the game.
I would try turning the graphics settings down and see if it makes any difference.
Also checking if anyone else is caning your broadband at the time. :p
1 Apr 2014
Aberdeen
That is the bottom end of the 700-series gaming GPUs. Just a thought but the monitor is plugged into the GPU and not the motherboard video, isn't it?
Something you can do if you have a second monitor is to fire up Task Manager and look at CPU usage and GPU usage. If you don't have a second monitor use MSI Afterburner.
What does DXDiag produce if you click 'Display 1' or 'Next page'?
OP
29 Nov 2020
yes i belive my monitor is plugged into my gpu and not my mb.
Display Devices
Card name: NVIDIA GeForce GTX 750 Ti
Manufacturer: NVIDIA
Chip type: GeForce GTX 750 Ti
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_1380&SUBSYS_84BB1043&REV_A2
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 14291 MB
Dedicated Memory: 2007 MB
Shared Memory: 12283 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.632812,0.350586), Green(0.322266,0.629883), Blue(0.152344,0.049805), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: AOC 2270W
Monitor Model: 2270W
Monitor Id: AOC2270
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HD15
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll
Driver File Version: 27.21.0014.5730 (English)
Driver Version: 27.21.14.5730
DDI Version: 12
Feature Levels: 11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:False Enabled:False
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 06/11/2020 00:00:00, 1038184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71E3E-50C0-11CF-9165-B5A418C2D635}
Vendor ID: 0x10DE
Device ID: 0x1380
SubSys ID: 0x84BB1043
Revision ID: 0x00A2
Driver Strong Name: oem6.inf:0f066de3a79f2f53:Section024:27.21.14.5730:pci\ven_10de&dev_1380
Rank Of Driver: 00CF2001
24 May 2006
Surrey - UK
If anything, turning the settings down in the game will at least tell you if the GPU is struggling, doesn't matter if the visuals look bad, it's for diagnostical purposes.
Depends how CPU heavy the game is though, lowering the settings might actually offload more work to the CPU, which could (in some cases) not help.
Requirements for the game are reasonably low though, but you need to play around with the settings to see if anything changes with adjustments.
6 Dec 2007
Cambridge
The requirements are a bit vague - presumably they mean it'll run on a very low end 700 series card, rather than a 780ti.
Check your drivers first. Start with the latest from Nvidia, then have a look at the steam forums in case it needs something older. Have you tried a dsl speed test lately?
27 Oct 2005
google suggests the Min spec cpu is a mobile i3-5005u, pretty much the same core speed as your 930 (i doubt the game uses more than a single core)
you will need to run with lower settings, maybe even minimum, the i3-5005 recommendation is apparently for 1280x720. what are you running at?
31 Aug 2017
PC is lowis spec, although game doesnt seem to need a high spec but even so almost always when i see a poorly performing computer its maxing out either cpu at 100% or disk in task manager.
Remember you need grunt for updates, virus checkers and other system resources or tasks you might not know about.
Also 90% of home built pcs i see have MS drivers on all peripherals like GPUs and storage drivers... nope.... nope and nope.
28 Sep 2020
Chicago
For more information on Speakers please visit the website here https://www.walkermcguire.com/
Memory: 24576MB RAM
Does online gaming affect Internet speed?
