Caporegime
So far AIB ones are making <2700Mhz>
HUB has a Sapphire one that's 2660Mhz.
Der8re get his Powercolour Red Devil to just over 2700Mhz.
JayZ2cents has a XFX one that also ran at just over 2700Mhz.
These are consistent and stable.
The problem getting past that is twofold, 2800Mhz limit and the +15% power limit, if the 3090XT gets a higher power limit and 3Ghz i think they would get 2800Mhz+, some might make it to 2900Mhz, the 3900XT's are also going to be the best binned chips. Like the Zen 2 3950X was and Zen 3 5950X is.
Even lower on the XFX also at 2.7Ghz, the Hotspot is ~70c with low RPM fans and its a good-looking card.And the temps on Red Devil are under 70C @2.7Ghz. It may look ugly but the quality of the card is first class.
Cause the power draw on those cards are low - 70c isn't actually that impressive, it's towards the better end of the cards but you'll see the asus strix will be another 5-6c cooler than that
Well RD was ~60C on der8auer video ( 55C after liquid metal ) but he kept it outside of a case, like Jayz did with the Merc. Inside it will get a little warmer.Even lower on the XFX also at 2.7Ghz, the Hotspot is ~70c with low RPM fans and its a good-looking card.
How is that comparison Ampere mobile to Turing desktop? The slides show where the new Ampere mobile gen is priced/positioned relative to the old mobile Turing mobile gen. It says nothing about desktop and that wouldn't even make contextual sense in a MOBILE roadmap.Now here is a big opportunity for AMD.
Nvidia is releasing it's mobile RTX3000 cards soon as they've had to cut down the chip's significantly to get them into a laptop's power limit envelope.
As such, the fastest laptop RTX3000 gpu will only match the desktop RTX2080 https://www.techpowerup.com/275358/...-part-comparable-to-desktop-rtx-2080s#g275358
I reckon AMD can come up with something that's faster than that, uses less power and is cheaper to make - big opportunity to beat Nvidia in the mobile market
6700xt is potentially faster than 6800/6800xt because it can overclock significantly higher
The 6700xt is most likely the same gpu that's inside the Xbox series x (52cu) but this desktop version looks like it can hit 3ghz
https://wccftech.com/amd-radeon-rx-6700-xt-custom-models-boost-up-to-2-95-ghz-220w-tgp/
