5 computers on a network - only the HP Microserver seems to be visible to all?
27 Feb 2004
Kent
I have 3 pcs, 1 HP gen 8 Microserver, 1 Lenovo laptop, an HP LAN connected printer, a Western digital media player and an IP camera, on a partially wired / partially Devolo Homeplug / partially Wifi network.
The VM router is connected to an 8 port switch. This is connected to some wired PCs and 20 a Devolo Homeplug. Other Devolo homeplugs are placedf around the huse
All devices can see the internet via wired / Devolo / Wifi connections. ALL devices can print to the HP LAN connected printer (including several Tablets and an iPad via "sharing".
Making the Win 10 devices see each other seems more difficult - networking with XP seemed easier!!!!
In the good old days of workgroups / Win 7, early Win 10 I could generally see each device from another and transfer files to other PCs. Usually had to sign in to common accounts etc but didn't find it a problem to "see" other PCs.
Now when i Power up the HP microserver (don't leave it on all of the time), I can see this device from the other PCs and read / write from / to it as long as I create a share on the drives I want to access.
I seem, however, to have great difficulty in sharing information reliably across the various Win 10 PCs, seeing the IP camera and writing files to the WD media player. Sometimes they work sometimes they don't
A couple of years ago they all seemed to connect sweetly! What has microsoft done?
I think it has removed "workgroups" - it has probalby updated other things I don't know about
I have even managed to create a share on a Raspberry Pi 4 and make that visible. to the HP Microserver
Is there somewhere where I can find the do's and don'ts of Windows 10 home networking please? There are 3 Windows 10 home devices and 2 Windows 10 pro devices. The HP Microserver, which seems to work OK without doing anything is Win 10 home.
Help please! Mel
Probably need to use SMB1.0/CIFS stuff in control panel.
Never heard of this before! - went to control panel - "Turn windows features and an off" - "Client was ticked. SMB 1.0 / CIFs Server wasn't - so clicked this "Server" - 15 minutes later still "searching for required files" - it cannot seem to find them!!
Where is the explanation for this stuff - any suggestion please - don't like following instructions "blind".
Failed to find the "SMB 1.0 / CIFs Server" required files after 30 minutes - obviously not going to find them??
Suggestions?
Which box is acting as DNS?
PC given IP Address by router, All named and given the same workgroup name in "System" panel
Which sort of sharing have you used?
Right click on drive, Properties, choose advanced sharing, tick box and give it a share name. Set permissions.
Have you set up access credentials in Certificate Manager?
How do I do this please !?
All this fiddling - one pc can now see itself and 2 other in "network" group and I can access the files on the other 2 PCs from that PC.
BUT not from the other 2 PCs? - i.e. not reciprocal behaviour.
I think you might be best off by mapping a drive manually on all the systems to the network drive.
Start > run > CMD > Type "net user \\server.ip\share /user:username password /persistant:yes"
This has documentation;
Net use | Microsoft Docs or "net use /?" gives help.
Thanks. I have an old D-Link NAS mapped that way - that works for that device - will perhaps try that.
Perhaps one of the problems is that none of the PCs is left on - they are all turned on / off as and when required. I suspect if I left them all on they would eventually see each other.
