X470 AORUS GAMING 7 WIFI with 2 Nvme issues
6 Oct 2012
Hi guys how are you?
I have X470 AORUS GAMING 7 WIFI Motherboard, today i received one nvme i already have one at the x4 slot, this one i installed at the x2 port at the bottom, it works but my Soundblaster Ax5 card stops working with the nvme installed, if i remove the bottom nvme it comes back working
What can i do to solve this issue?
It designed that way could try he sound card in the second gpu slot.
The PCIEX4 slot becomes unavailable when a device is installed in the M2B_SOCKET connector.
Thanks, nut if i populate the second slot the gpu goes to X8
I had to use the pci 1x in the top of the card, not the best solution... but the only one that worked
