Looking to upgrade graphics card
2 Dec 2020
Hi Guys
Looking for some advice on upgrading a graphics card.
My current spec:
AMD Ryzen 7 2700
GTX 1660 Ventus XS 6gb
Gigabyte A320M-SH2 AMD AM4 motherboard
32gb RAM
500w 80+PSU
This is my first upgrade and not sure if I can just change the graphics card or if I have to change anything else to support.
Thanks
Edited to add: I have recently upgraded my TV so my resolution has changed from 1280x720 to 3840x2160 60htz
I think I read that the 60htz is basically 60fps, I'm currently getting 30 and under on max settings
15 Mar 2010
Bucks
If your now gaming at 4k you need a new GPU. 3080 or equivalent. You wont be able to get one for months though.
You would also need a new PSU for the new card as 500w wont cut it. Nothing wrong with the rest of your setup.
OP
2 Dec 2020
Hi what are you trying to achieve is your pc struggling , e.g playing games at a higher resoloution ?
Do you have an ssd ?
Budget ?
no budget, happy to spend for something that will last
Currently have the OS on a 120gb 2.5 SATA III SSD and everything else on 1TB SATA III HD
OP
2 Dec 2020
yeah I see there is a shortage of GPUs at the moment
would 850w be adequate for a 3080?
