- 10 Jan 2004
- Poland
What fans are you using?
6x Deepcool RF120,they are good fans.What fans are you using?
If the backplate is hot then it is doing it's job.I think one of the problems is backplate temp. it gets quite toasty and the case struggles to get rid of the heat
and 3 NZXT fans that came with Kraken X73 AIO.
Am guessing that around normal with the default fan speed settingsCPU temps are good but 3080 FE quickly reaches 68-74 under load.(within 20 minutes).
