Hey guys,
I have a little problem with my pc. It was working ok this morning but when i went to go on it tonight it will not boot. I have tried swapping out the ram, reseating gpu and cpu and checked all cables to make sure nothing has come loose and cleared cmos with no luck.
The CPU/DRAM lights on the board just keep flashing back and forth and the rgb on the gpu flashes on and off, also the rgb strips wont light up.
Do you think im looking at a dead motherboard ? It's been running ok now for over a year with no problems.
Gigabyte Aorus b450m
Ryzen 1600
16gb DDR4 Hyper Predator
Gigabyte rx570 8gb
Samsung ssd
Be-quiet 500watt
Thank you.
Ryzen 1600
Gigabyte rx570 8gb
Samsung ssd
Be-quiet 500watt
Thank you.
