- 31 May 2016
Hello,
So I'm a little confused regarding CPUs and higher resolutions. I've always been under the impression that a major CPU is not required when running high res. I just got my 3080 Eagle today and I've been running some games with it.
My monitor is 32:9 running at 5120x1440. Correct me if I'm wrong but I would assume thats a similar render resolution to 4k.
Anyway, I've started testing Call Of Duty Black Ops Cold War and just wacked everything to Max with DLSS on Performance. Game looks great and can get as high as 80Fps in some areas. But I noticed I'm only getting about 50% GPU usage even at this resolution. My monitor is 100hz so it can go up to 100fps.
So I've just got to the Vitanam level and my framerate totally tanked to 20fps/30fpsish. GPU usage is low and CPU usage is hovering around 80/90%.
For me it sounds like I blatant CPU bottleneck, I have a i7 7700k running at 4.4ghz and 16GB of 3200mhz ram. Overclocking the CPU anymore screws my temps.
I've checked over benchmarks on Youtube with similar setups but with a Ryzen 5600x and they are getting 80fps in that Vitaman area. Bare in mind this is at 4K resolution, not 5120x1440.
The reason I'm posting this is because I was under the impression by others that my i7 7700k would easily handle this at my resolution because it should be forcing the 3080 into the bottleneck. Instead it seems to me its the other way around.
I just wanted to make 100% sure that it is indeed CPU bound before I go ahead and buy something.
Thanks for all your help.
