Newbie here Warzone player
3 Dec 2020
Hi all
Wondering if anyone can help me with specs needed to run warzon on Pc. Im not looking to spend the earth. Budget aprox 650. I have a current pc but have been advised its not worth upgrading.
Current specs
Intel i7 3770
Nvidea hd 5450
16gb ram
120 gb storage
Think thats everything
Currently on a lg 27650f monitor
Hope you can all help.
While your system is old its stll worth putting in a better graphics card this will allow you to play warzone.
A 1660 super would be a decent gpu and you would have funds to upgrade cpu motherboard and ram later if needed.
What Psu do you have ?
Hi thanks for your speedy reply.
Psu looks original at 300w
Case is a dell vostro
Many thanks
Nathan
You would have to change the psu for a 1660 super but being a dell mite not be so easy,you would have be to check.
You could just add 1650 that wouldn't require any extra power but not sure how well it would play warzone.
Gpu prices ard high at thd momment.
What model number is dell vistro ?
