Did you guys find in use it reduced at all after a while?
tempted to send mine back within 14 days. Idea was it eventually will go under water in a HTPC, yet I can still hear the whine clearly about 3 meters away on the couch and this is with music and ambient noise from games with a atmos setup. Tried with couple of PSUs including my AX1600i which is extremely solid and still it whines so concerned this may not go away even after use. Will be thrashing it this weekend with watchdogs but doubt it will change anything. This is with LG OLED so can go up to 120hz at 4K, but whine happens at any FPS to be honest, all benchmarks I have tried thus far and some games.
I wouldn’t get too fixated on replacing cards. I’ve been through 20+ 1080Ti/2080Ti’s and nothing made much difference.
Play around with an undervolt is your best bet. Could get a 60% power reduction on my 2080Ti for just above 5% in total performance at 4k. Ampere could be similar.
You could also try blocking all your case vents especially the rear. You’d be suprised how much noise comes out the back of a GPU.
