Running 3600mhz (2x16gb) Patriot Viper steel ram
Ryzen 5600X
MSI B550 Gaming Edge Wifi board
I had this ram running in an intel setup (9700k) at 3600mhz ok prior to putting it in this, so i know that it can do those speeds at its XMP settings anyway...however in this I'm struggling.
I can't get the system stable, even with slightly increased voltage and laxed timings at anything over 3200mhz. If i set it to 2T i can make it stable enough to at least let me get back into the bios. I'm setting FCLK and infinity fabric to 1800mhz, UCLK to = memoryclk, power down enable is disabled and gear down mode disabled, as is bank group swap (i don't know what that does, just read recommendations to turn it off) and ram running at 1.36v (actual voltage was showing 1.33 when set to 1.35, 1.36v gives a better reading)
Any suggestions? I'm thinking i might just send this stuff back and get something else at the moment as I'm getting fed up
Edit: additional note, it's been years since I did anything beyond the most basic overclocking. Setting xmp to enabled was all the effort I went through on my last setup, fancy getting a bit more out of this one though. So I may be missing something obvious.
Ryzen 5600X
