I bought a coach!
Just treated myself to an Early Christmas Present coz tools are important https://www.primetools.co.uk/produc...dule-tool-kit-in-c24s8-roller-cabinet-orange/ I have a history with Beta tools from my racing days.
Also have a selection of Makita 18V LXT Power tools coming and 5x 5.0AH battery packs. I have another £1700 in the budget for tools such as Mitre Saw, Table Saw, Planer and Air Tools which I can run from the Coach's own air system.
Could you get a Smart car in there? They are small. If you're going to spend years living in the coach then I'd suggest a small car rather than a bike. But if you go down the bike route then a little Honda MSX125 (known as a Grom) is tiny.
Also, consider how you're going to insulate the coach for cold weather.
Easier to just tow it, but more likely to go electric of some description by the time it is required. Electric bikes aregood value and can be q uite fast if you have the appropriate licence (i do).
LMAO, sadly they didn't have a wood burning stove in that planner software :)
From your list of stuff I was expecting a workshop in there. :p
Also if you dont install a glass chandalier somewhere which swings and clatters around as you drive I will be very disappointed.
amazing - looking forward to seeing this one progress. Whats the plan for the luggage space underneath? wine cellar?
A lot of storage, Minisplit Pump, Waste tanks, Electrical equipment and Tools
I assume considering the scale of the project your small tow car will be something like a 7 series ;)
750Kg is the limit afaik, otherwise it would be my E-class :D
The world is my workshop, and sorry discrete LED lighting I am afraid.
If you're after anything else from Beta let me know - I have a rep in my phone book who may be able to assist.
I remember when I was in America you would see these massive RV's towing all sorts of cars on the back not just small little things. Then again we do not have the roads for it.
I am jealous of not only the coach... but also your tools lol
Because of the combined size and weight you need an HGV Class 1 Articulated licence if the "trailer" is over 750Kg and you cannot A-Frame tow in the EU like you can in the US.
Decent tools are important :D
