Windows 10 20H2 update problem
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Twice windows has installed this update in the background, when it restarts its like its constantly resetting Explorer.exe at a rate of about once per second rendering the PC completely unusable, like its refreshing the desktop over and over again at high speed.
I can't give you error codes as i'm not installing it again as i'm sick of reinstalling Windows at this point.
I have Windows update on pause but if anyone could tell me what's wrong here because i can't just keep windows update on pause permanently.
Ryzen 3600
RTX 2070 Super
ASRock B350 Pro 4
32GB (2X 16GB) Vulcan Z
EVGA 650 GS
Gammaxx L120 AIO
WD 500GB NVMe (Boot Drive)
Crucial 1TB SATA SSD
WD 256GB M.2 SATA SSD
1TB spinny disk.
Corsair K70 KB
Cougar Minos X2 Mouse
Corsair HS70 Head Set
AOC Q3279VWFD8 Screen.
System Information
Time of this report: 12/12/2020, 12:36:57
Machine name: DESKTOP-9CBLHI2
Machine Id: {8B5D4D2B-336B-421B-9E1C-19533889C057}
Operating System: Windows 10 Pro 64-bit (10.0, Build 19042) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: P6.40 (type: UEFI)
Processor: AMD Ryzen 5 3600 6-Core Processor (12 CPUs), ~3.6GHz
Memory: 32768MB RAM
Available OS Memory: 32696MB RAM
Page File: 8720MB used, 29096MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 192 DPI (200 percent)
DWM DPI Scaling: UnKnown
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0546 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce RTX 2070 SUPER
Manufacturer: NVIDIA
Chip type: GeForce RTX 2070 SUPER
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_1E84&SUBSYS_373E1462&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 24359 MB
Dedicated Memory: 8011 MB
Shared Memory: 16348 MB
Current Mode: 2560 x 1440 (32 bit) (75Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.672852,0.319336), Green(0.267578,0.672852), Blue(0.151367,0.060547), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: Q3279WG5B
Monitor Id: AOC3279
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvldumdx.dll
Driver File Version: 27.21.0014.5751 (English)
Driver Version: 27.21.14.5751
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:True Enabled:False
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 22/11/2020 00:00:00, 1039376 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71E3E-5DC4-11CF-A561-30171BC2D635}
Vendor ID: 0x10DE
Device ID: 0x1E84
SubSys ID: 0x373E1462
Revision ID: 0x00A1
Driver Strong Name: oem12.inf:0f066de3ed1dddbd:Section001:27.21.14.5751:pci\ven_10de&dev_1e84
Rank Of Driver: 00CF2001
Video Accel:
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {20BB8B0A-97AA-4571-8E99-64E60606C1A6} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C} {8A1A1031-29BC-46D0-A007-E9B092CA6767}
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 4
MPO Caps: YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,IMMEDIATE,HDR (MPO3)
MPO Stretch: 10.000X - 0.500X
MPO Media Hints: resizing, colorspace Conversion
MPO Formats: NV12
PanelFitter Caps: YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,IMMEDIATE,HDR (MPO3)
PanelFitter Stretch: 10.000X - 0.500X
Sound Devices
Description: Headset Earphone (Corsair HS70 Wireless Gaming Headset)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_1B1C&PID_0A38&REV_0000&MI_00
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: USBAUDIO.sys
Driver Version: 10.0.19041.388 (English)
WHQL Logo'd: Yes
Date and Size: 07/07/2020 00:00:00, 202752 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Emulation Only
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Q3279WG5B (NVIDIA High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0092&SUBSYS_1462373E&REV_1001
Product ID: N/A
Type: N/A
Driver Name: nvhda64v.sys
Driver Version: 1.3.38.16 (English)
WHQL Logo'd: Yes
Date and Size: 24/07/2019 00:00:00, 237424 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Headset Microphone (Corsair HS70 Wireless Gaming Headset)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: COUGAR Minos X2
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04D9, 0xA09E
FF Driver: n/a
Device Name: HID-compliant vendor-defined device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B13
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Hid Interface
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x0A38
FF Driver: n/a
Device Name: HID-compliant consumer control device
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x1022, 0x43BB
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 10/9/2020 20:46:37, 647992 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 10/9/2020 20:46:37, 185664 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 12/7/2019 09:07:56, 44032 bytes
| | | Driver: hidclass.sys, 12/7/2019 09:07:56, 225792 bytes
| | | Driver: hidparse.sys, 12/7/2019 09:07:56, 46080 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 12/7/2019 09:07:56, 46592 bytes
| | | | Driver: kbdclass.sys, 12/7/2019 09:07:56, 71480 bytes
| | Service: usbccgp
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 12/7/2019 09:07:56, 35328 bytes
| | | | Driver: mouclass.sys, 12/7/2019 09:07:56, 67600 bytes
| | | Service: HidUsb
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 186.8 GB
Total Space: 476.3 GB
File System: NTFS
Model: WDC WDS500G1B0C-00S6U0
Drive: D:
Free Space: 276.5 GB
Total Space: 953.9 GB
File System: NTFS
Model: CT1000BX500SSD1
Drive: E:
Free Space: 106.1 GB
Total Space: 238.5 GB
File System: NTFS
Model: WDC WDS250G1B0B-00AS40
Drive: F:
Free Space: 149.0 GB
File System: NTFS
Model: ST1000DM003-1ER162
System Devices
Name: PCI Express Downstream Switch Port
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&752B2A7&0&08020B
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.19041.0488 (English), 10/9/2020 20:46:37, 472376 bytes
Device ID: PCI\VEN_1022&DEV_790B&SUBSYS_790B1022&REV_61\3&11583659&0&A0
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1447&SUBSYS_00000000&REV_00\3&11583659&0&C7
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&752B2A7&0&00020B
Name: AMD PSP 11.0 Device
Device ID: PCI\VEN_1022&DEV_1486&SUBSYS_14861022&REV_00\4&1FDE7688&0&0141
Driver: C:\Windows\system32\DRIVERS\amdpsp.sys, 4.13.0000.0000 (English), 3/24/2020 11:11:18, 135184 bytes
Driver: C:\Windows\system32\amdtee_api.dll, 4.13.0000.0000 (English), 3/24/2020 11:11:20, 442384 bytes
Driver: C:\Windows\SysWOW64\amdtee_api.dll, 4.13.0000.0000 (English), 3/24/2020 11:11:20, 355856 bytes
Name: NVIDIA USB Type-C Port Policy Controller
Device ID: PCI\VEN_10DE&DEV_1AD9&SUBSYS_373E1462&REV_A1\4&1FC990D7&0&0319
Driver: C:\Windows\system32\DRIVERS\UcmCxUcsiNvppc.sys, 1.01.0027.0831 (English), 10/4/2019 16:15:28, 469736 bytes
Device ID: PCI\VEN_1022&DEV_1442&SUBSYS_00000000&REV_00\3&11583659&0&C2
Driver: n/a
Name: Standard NVM Express Controller
Device ID: PCI\VEN_15B7&DEV_5003&SUBSYS_500315B7&REV_01\4&2B5FE750&0&0009
Driver: C:\Windows\system32\DRIVERS\stornvme.sys, 10.00.19041.0546 (English), 10/9/2020 20:46:37, 155960 bytes
Name: PCI Express Upstream Switch Port
Device ID: PCI\VEN_1022&DEV_43B2&SUBSYS_02011B21&REV_02\4&2C18E2E3&0&020B
Device ID: PCI\VEN_1022&DEV_1445&SUBSYS_00000000&REV_00\3&11583659&0&C5
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_1022&DEV_1487&SUBSYS_68931849&REV_00\4&1FDE7688&0&0441
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.19041.0001 (English), 12/7/2019 09:07:50, 132608 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.19041.0001 (English), 12/7/2019 09:07:50, 97792 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.19041.0001 (English), 12/7/2019 09:07:50, 389120 bytes
Device ID: PCI\VEN_1022&DEV_1485&SUBSYS_14851022&REV_00\4&1FDE7688&0&0041
Driver: C:\Windows\system32\DRIVERS\AMDPCIDev.sys, 1.00.0000.0081 (English), 10/6/2020 11:12:42, 34096 bytes
Device ID: PCI\VEN_1022&DEV_1440&SUBSYS_00000000&REV_00\3&11583659&0&C0
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1022&DEV_790E&SUBSYS_790E1022&REV_51\3&11583659&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.19041.0001 (English), 12/7/2019 09:07:54, 20280 bytes
Device ID: PCI\VEN_10DE&DEV_10F8&SUBSYS_373E1462&REV_A1\4&1FC990D7&0&0119
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&40
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&38
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&28
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&20
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&18
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&10
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&08
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1480&SUBSYS_14501022&REV_00\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1443&SUBSYS_00000000&REV_00\3&11583659&0&C3
Driver: n/a
Name: AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
Device ID: PCI\VEN_1022&DEV_149C&SUBSYS_79141022&REV_00\4&1FDE7688&0&0341
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.19041.0488 (English), 10/9/2020 20:46:37, 602440 bytes
Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.19041.0488 (English), 10/9/2020 20:46:37, 137408 bytes
Device ID: PCI\VEN_1022&DEV_43BB&SUBSYS_11421B21&REV_02\4&2C18E2E3&0&000B
Device ID: PCI\VEN_1022&DEV_1446&SUBSYS_00000000&REV_00\3&11583659&0&C6
Driver: n/a
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1022&DEV_43B7&SUBSYS_10621B21&REV_02\4&2C18E2E3&0&010B
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.19041.0488 (English), 10/9/2020 20:46:37, 185672 bytes
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&752B2A7&0&38020B
Name: Realtek PCIe GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_81681849&REV_11\868861C28570000000
Driver: C:\Windows\system32\DRIVERS\rt640x64.sys, 9.01.0410.2015 (English), 12/7/2019 09:07:54, 694272 bytes
Name: PCI Express Root Port
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14841022&REV_00\3&11583659&0&43
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14841022&REV_00\3&11583659&0&42
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14841022&REV_00\3&11583659&0&41
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14841022&REV_00\3&11583659&0&39
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_12341022&REV_00\3&11583659&0&19
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_12341022&REV_00\3&11583659&0&0B
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_12341022&REV_00\3&11583659&0&09
Device ID: PCI\VEN_1022&DEV_148A&SUBSYS_148A1022&REV_00\4&D573D7&0&0039
Name: NVIDIA GeForce RTX 2070 SUPER
Device ID: PCI\VEN_10DE&DEV_1E84&SUBSYS_373E1462&REV_A1\4&1FC990D7&0&0019
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\MessageBus.dll, 1.22.2758.1620 (English), 11/23/2020 13:47:58, 7534488 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\NVDisplay.Container.exe, 1.28.2851.9944 (English), 11/23/2020 13:47:58, 893848 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\NvContainerRecovery.bat, 11/22/2020 13:36:49, 1951 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\messagebus_client.conf, 11/22/2020 13:36:49, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\nvgwls.exe, 11/23/2020 13:48:00, 39648664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\nvtopps.db3, 11/22/2020 13:36:49, 81920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\LocalSystem\NvXDCore.dll, 27.21.0014.5751 (English), 11/23/2020 13:48:04, 1782680 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\LocalSystem\NvcDispCorePlugin.dll, 27.21.0014.5751 (English), 11/23/2020 13:48:02, 520432 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\LocalSystem\NvcDispWatchdog.dll, 1.28.2851.9944 (English), 11/23/2020 13:48:02, 628464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\LocalSystem\_DisplayDriverRAS.dll, 1.10.0000.0000 (English), 11/23/2020 13:48:06, 2571160 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\LocalSystem\_NvMessageBusBroadcast.dll, 1.28.2851.9944 (English), 11/23/2020 13:48:06, 3153648 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\LocalSystem\messagebus.conf, 11/22/2020 13:36:49, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\Session\NvFBCPlugin.dll, 6.14.0014.5751 (English), 11/23/2020 13:48:08, 1357040 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\Session\_nvppo.dll, 27.21.0014.5751 (English), 11/23/2020 13:48:12, 1610648 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\Session\_nvtopps.dll, 27.21.0014.5751 (English), 11/23/2020 13:48:14, 8468208 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\Session\nvprofileupdaterplugin.dll, 27.21.0014.5751 (English), 11/23/2020 13:48:08, 2163440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\Session\nvxdsyncplugin.dll, 8.17.0014.5751 (English), 11/23/2020 13:48:10, 1798896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\Display.NvContainer\plugins\Session\wksServicePlugin.dll, 27.21.0014.5751 (English), 11/23/2020 13:48:10, 570776 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 27.21.0014.5751 (English), 11/23/2020 13:42:52, 730008 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 11/22/2020 13:36:49, 1717136 bytes
Driver: C:\Windows\system32\nvcpl.dll, 8.17.0014.3200 (English), 10/4/2019 16:13:02, 5443976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nv3dappshext.dll, 6.14.0014.5751 (English), 11/23/2020 13:43:08, 1000856 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nv3dappshextr.dll, 6.14.0014.5751 (English), 11/23/2020 13:43:10, 93080 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvcoproc.bin, 11/22/2020 13:36:49, 9340317 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvcpl.dll, 8.17.0014.5751 (English), 11/23/2020 13:43:34, 5519600 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvdevtools.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:04, 4536728 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvdevtoolsr.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:06, 234392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvdisps.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:08, 11582704 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvdispsr.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:10, 11147160 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvgames.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:32, 12304624 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvgamesr.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:32, 12449688 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvlicensings.dll, 6.14.0014.5751 (English), 11/23/2020 13:45:08, 4537240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvlicensingsr.dll, 6.14.0014.5751 (English), 11/23/2020 13:45:10, 291568 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvshext.dll, 1.02.0000.0001 (English), 11/23/2020 13:47:02, 129776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsmartmax.dll, 6.14.0010.10003 (English), 11/23/2020 13:47:04, 204184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsmartmax64.dll, 6.14.0010.10003 (English), 11/23/2020 13:47:04, 243608 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsmartmaxapp.exe, 6.14.0010.10003 (English), 11/23/2020 13:47:06, 273136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsmartmaxapp64.exe, 6.14.0010.10003 (English), 11/23/2020 13:47:08, 283888 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsvc64.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:08, 2644888 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsvcr.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:10, 1767664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsvs.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:12, 5055384 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvsvsr.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:14, 1946864 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvui.dll, 8.17.0014.5751 (English), 11/23/2020 13:47:16, 6562544 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvuir.dll, 8.17.0014.5751 (English), 11/23/2020 13:47:20, 2490608 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvvitvs.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:24, 7399832 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvvitvsr.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:26, 4113816 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvwss.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:32, 12064496 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvwssr.dll, 27.21.0014.5751 (English), 11/23/2020 13:47:32, 9346288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvxdapix.dll, 8.17.0014.5751 (English), 11/23/2020 13:47:36, 9016216 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvxdbat.dll, 8.17.0014.5751 (English), 11/23/2020 13:47:40, 1606384 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvxdplcy.dll, 8.17.0014.5751 (English), 11/23/2020 13:47:42, 1856240 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\license.txt, 10/4/2019 15:53:30, 27216 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\cudnn_infer64_7.dll, 11/23/2020 13:42:46, 22773136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvngx.dll, 27.21.0014.5751 (English), 11/23/2020 13:45:14, 1426328 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvngx_update.exe, 27.21.0014.5751 (English), 11/23/2020 13:45:16, 976280 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Adjustments.yaml, 11/22/2020 13:36:49, 8964 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Adjustments.yfx, 11/22/2020 13:36:49, 1271 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\BlacknWhite.yaml, 11/22/2020 13:36:49, 5774 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\BlacknWhite.yfx, 11/22/2020 13:36:49, 1080 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Color.yaml, 11/22/2020 13:36:49, 5298 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Color.yfx, 11/22/2020 13:36:49, 1951 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Colorblind.yaml, 11/22/2020 13:36:49, 3853 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Colorblind.yfx, 11/22/2020 13:36:49, 1531 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\DOF.yaml, 11/22/2020 13:36:49, 16008 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\DOF.yfx, 11/22/2020 13:36:49, 12413 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Details.yaml, 11/22/2020 13:36:49, 5222 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Details.yfx, 11/22/2020 13:36:49, 4077 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\FreqTransfer32.exe, 11/23/2020 13:48:18, 3723672 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\FreqTransfer64.exe, 11/23/2020 13:48:18, 4067736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\GreenScreen.yaml, 11/22/2020 13:36:49, 5882 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\GreenScreen.yfx, 11/22/2020 13:36:49, 2034 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\GreenScreenBG01.jpg, 11/22/2020 13:36:49, 281528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\GreenScreenBG02.jpg, 11/22/2020 13:36:49, 499736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\HighresBlender32.exe, 11/23/2020 13:48:20, 3828464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\HighresBlender64.exe, 11/23/2020 13:48:20, 4186352 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\LDR_RGB1_18.png, 11/22/2020 13:36:49, 3671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Letterbox.yaml, 11/22/2020 13:36:49, 3295 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Letterbox.yfx, 11/22/2020 13:36:49, 1319 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NightMode.yaml, 11/22/2020 13:36:49, 1738 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NightMode.yfx, 11/22/2020 13:36:49, 552 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NvCamera32.dll, 7.00.0636.0672 (English), 11/23/2020 13:48:22, 6975728 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NvCamera64.dll, 7.00.0636.0672 (English), 11/23/2020 13:48:22, 7868312 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NvCameraAllowlisting32.dll, 7.00.0636.0672 (English), 11/23/2020 13:48:24, 556952 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NvCameraAllowlisting64.dll, 7.00.0636.0672 (English), 11/23/2020 13:48:24, 696560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NvCameraEnable.exe, 11/23/2020 13:48:26, 371096 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NvImageConvert32.exe, 11/23/2020 13:48:26, 3749272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\NvImageConvert64.exe, 11/23/2020 13:48:28, 4081560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\OldFilm.yaml, 11/22/2020 13:36:49, 7473 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\OldFilm.yfx, 11/22/2020 13:36:49, 2746 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Posterize.fx, 11/22/2020 13:36:49, 12310 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\ReShadeFXC32.exe, 2.00.0000.0000 (English), 11/23/2020 13:48:30, 725912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\RemoveHud.yaml, 11/22/2020 13:36:49, 459 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\RemoveHud.yfx, 11/22/2020 13:36:49, 776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sharpen.yaml, 11/22/2020 13:36:49, 3030 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sharpen.yfx, 11/22/2020 13:36:49, 4993 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\ShotWithGeforce518x32.rgba, 11/22/2020 13:36:49, 66304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\SpecialFX.yaml, 11/22/2020 13:36:49, 14100 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\SpecialFX.yfx, 11/22/2020 13:36:49, 13357 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\SphericalEquirect32.exe, 11/23/2020 13:48:30, 3699440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\SphericalEquirect64.exe, 11/23/2020 13:48:32, 3982576 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Splitscreen.yaml, 11/22/2020 13:36:49, 9609 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Splitscreen.yfx, 11/22/2020 13:36:49, 7203 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker01.png, 11/22/2020 13:36:49, 49695 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker02.png, 11/22/2020 13:36:49, 474002 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker03.png, 11/22/2020 13:36:49, 380006 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker04.png, 11/22/2020 13:36:49, 86881 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker05.png, 11/22/2020 13:36:49, 59304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker06.png, 11/22/2020 13:36:49, 13547 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker07.png, 11/22/2020 13:36:49, 6342 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Sticker08.png, 11/22/2020 13:36:49, 96493 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Stickers.yaml, 11/22/2020 13:36:49, 10323 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Stickers.yfx, 11/22/2020 13:36:49, 3989 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\TiltShift.yaml, 11/22/2020 13:36:49, 4656 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\TiltShift.yfx, 11/22/2020 13:36:49, 4849 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Vignette.yaml, 11/22/2020 13:36:49, 4677 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\Vignette.yfx, 11/22/2020 13:36:49, 1823 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\YAMLFXC32.exe, 11/23/2020 13:48:32, 1067928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\d3dcompiler_47_32.dll, 6.03.9600.16384 (English), 11/23/2020 13:48:14, 3467504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\d3dcompiler_47_64.dll, 6.03.9600.16384 (English), 11/23/2020 13:48:16, 4174576 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\filternames.cfg, 11/22/2020 13:36:49, 14012 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\fxtools.cfg, 11/22/2020 13:36:49, 65 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\scratches.jpg, 11/22/2020 13:36:49, 346354 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\tools_licenses.txt, 11/22/2020 13:36:49, 12616 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvCamera\ui.tga, 11/22/2020 13:36:49, 120236 bytes
Driver: C:\Windows\system32\MCU.exe, 1.01.5204.20580 (English), 11/23/2020 13:43:06, 849648 bytes
Driver: C:\Windows\system32\nvdebugdump.exe, 6.14.0014.5751 (English), 11/23/2020 13:44:00, 445848 bytes
Driver: C:\Windows\system32\nvidia-smi.exe, 8.17.0014.5751 (English), 11/23/2020 13:44:40, 590576 bytes
Driver: C:\Windows\system32\nvml.dll, 8.17.0014.5751 (English), 11/23/2020 13:45:14, 1027992 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvopencl32.dll, 27.21.0014.5751 (English), 11/23/2020 13:45:44, 33988504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvopencl64.dll, 27.21.0014.5751 (English), 11/23/2020 13:45:54, 39600368 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvcompiler32.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:14, 35490200 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvcompiler64.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:24, 40632560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvlddmkm.sys, 27.21.0014.5751 (English), 11/23/2020 13:45:00, 33066392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nv-vk64.json, 11/22/2020 13:36:49, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvDecMFTMjpeg.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:00, 604568 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvDecMFTMjpegx.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:02, 746904 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvEncMFTH264.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:18, 1132952 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvEncMFTH264x.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:18, 1442544 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvEncMFThevc.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:20, 1138928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvEncMFThevcx.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:22, 1453464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvcbl64.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:10, 684440 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvcuda32.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:36, 19286256 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvcuda64.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:42, 22070000 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvd3dumx.dll, 27.21.0014.5751 (English), 11/23/2020 13:42:36, 27721784 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvd3dumx_cfg.dll, 27.21.0014.5751 (English), 11/23/2020 13:42:44, 27952072 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvdlistx.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:14, 209136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvldumdx.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:00, 1039376 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvoglv64.dll, 27.21.0014.5751 (English), 11/23/2020 13:45:32, 46767512 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvoptix.dll, 7.02.0000.0000 (English), 11/23/2020 13:46:08, 155447192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvptxJitCompiler32.dll, 27.21.0014.5751 (English), 11/23/2020 13:46:40, 8485272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvptxJitCompiler64.dll, 27.21.0014.5751 (English), 11/23/2020 13:46:42, 9086192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvrtum64.dll, 27.21.0014.5751 (English), 11/23/2020 13:46:46, 53092760 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvwgf2umx.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:16, 45019232 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvwgf2umx_cfg.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:30, 45408296 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0014.5751 (English), 11/23/2020 13:44:30, 2096880 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0014.5751 (English), 11/23/2020 13:44:54, 1507224 bytes
Driver: C:\Windows\system32\NvIFROpenGL.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:56, 670616 bytes
Driver: C:\Windows\system32\OpenCL.dll, 2.02.0005.0000 (English), 11/23/2020 13:47:48, 456600 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:26, 813464 bytes
Driver: C:\Windows\system32\nvapi64.dll, 27.21.0014.5751 (English), 11/23/2020 13:42:26, 7006712 bytes
Driver: C:\Windows\system32\nvcuda.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:52, 2508528 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0014.5751 (English), 11/23/2020 13:43:56, 7706352 bytes
Driver: C:\Windows\system32\nvinfo.pb, 11/22/2020 13:36:49, 80930 bytes
Driver: C:\Windows\system32\nvmcumd.dll, 27.21.0014.5751 (English), 11/23/2020 13:45:12, 816368 bytes
Driver: C:\Windows\system32\nvofapi64.dll, 11/23/2020 13:45:20, 674712 bytes
Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.02.0141.0000 (English), 11/23/2020 13:47:52, 1054936 bytes
Driver: C:\Windows\system32\vulkan-1.dll, 1.02.0141.0000 (English), 11/23/2020 13:47:52, 1054936 bytes
Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.02.0141.0000 (English), 11/23/2020 13:47:54, 1769688 bytes
Driver: C:\Windows\system32\vulkaninfo.exe, 1.02.0141.0000 (English), 11/23/2020 13:47:54, 1769688 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nv-vk32.json, 11/22/2020 13:36:49, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvIccAdvancedColorIdentity.icm, 11/22/2020 13:36:49, 3288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvd3dum.dll, 27.21.0014.5751 (English), 11/23/2020 13:42:28, 23442184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvd3dum_cfg.dll, 27.21.0014.5751 (English), 11/23/2020 13:42:52, 23827728 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvdispco64.exe, 1.00.0015.0000 (English), 11/23/2020 13:44:08, 1536240 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvdlist.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:14, 178072 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvldumd.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:00, 862656 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvoglv32.dll, 27.21.0014.5751 (English), 11/23/2020 13:45:22, 36323568 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvwgf2um.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:04, 39826672 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\nvwgf2um_cfg.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:44, 40458952 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0014.5751 (English), 11/23/2020 13:44:28, 1585560 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0014.5751 (English), 11/23/2020 13:44:52, 1159920 bytes
Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:56, 556440 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 2.02.0005.0000 (English), 11/23/2020 13:47:46, 349936 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 27.21.0014.5751 (English), 11/23/2020 13:44:24, 656112 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 27.21.0014.5751 (English), 11/23/2020 13:42:22, 5978008 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 27.21.0014.5751 (English), 11/23/2020 13:43:48, 4175256 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0014.5751 (English), 11/23/2020 13:43:54, 6860184 bytes
Driver: C:\Windows\SysWow64\nvofapi.dll, 11/23/2020 13:45:18, 543128 bytes
Driver: C:\Windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.02.0141.0000 (English), 11/23/2020 13:47:54, 917728 bytes
Driver: C:\Windows\SysWow64\vulkan-1.dll, 1.02.0141.0000 (English), 11/23/2020 13:47:54, 917728 bytes
Driver: C:\Windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.02.0141.0000 (English), 11/23/2020 13:47:56, 1370328 bytes
Driver: C:\Windows\SysWow64\vulkaninfo.exe, 1.02.0141.0000 (English), 11/23/2020 13:47:56, 1370328 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_372920ce6be76248\NvTelemetry64.dll, 14.03.0054.0000 (English), 11/23/2020 13:47:16, 4548496 bytes
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&752B2A7&0&28020B
Device ID: PCI\VEN_1B21&DEV_0612&SUBSYS_06121849&REV_02\6&49118D6&0&0030020B
Device ID: PCI\VEN_1022&DEV_1441&SUBSYS_00000000&REV_00\3&11583659&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&752B2A7&0&30020B
Name: NVIDIA USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
Device ID: PCI\VEN_10DE&DEV_1AD8&SUBSYS_373E1462&REV_A1\4&1FC990D7&0&0219
Device ID: PCI\VEN_1022&DEV_43B4&SUBSYS_33061B21&REV_02\5&752B2A7&0&20020B
Device ID: PCI\VEN_1022&DEV_1444&SUBSYS_00000000&REV_00\3&11583659&0&C4
Driver: n/a
Device ID: PCI\VEN_1022&DEV_7901&SUBSYS_79011022&REV_51\4&3298272D&0&0042
Device ID: PCI\VEN_1022&DEV_7901&SUBSYS_79011022&REV_51\4&9B70DCB&0&0043
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.19041.0508
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.19041.0508
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.19041.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.19041.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.19041.0450
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.19041.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.19041.0450
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.19041.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.19041.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.19041.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.19041.0329
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.19041.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.19041.0329
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.19041.0329
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.19041.0572
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.19041.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0329
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.19041.0329
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.19041.0329
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.19041.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.19041.0329
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.19041.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0329
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.19041.0329
DV Splitter,0x00600000,1,2,qdv.dll,10.00.19041.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.19041.0329
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.19041.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.19041.0329
Video Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0329
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.19041.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.19041.0329
Video Renderer,0x00400000,1,0,quartz.dll,10.00.19041.0329
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.19041.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.19041.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.19041.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.19041.0329
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.19041.0329
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.19041.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.19041.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.19041.0329
Null Renderer,0x00200000,1,0,qedit.dll,10.00.19041.0329
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.19041.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.19041.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.19041.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.19041.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0329
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.19041.0329
Wave Parser,0x00400000,1,1,quartz.dll,10.00.19041.0329
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.19041.0329
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.19041.0329
File stream renderer,0x00400000,1,1,quartz.dll,10.00.19041.0329
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.19041.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.19041.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.19041.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.19041.0329
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.19041.0329
File Source (URL),0x00400000,0,1,quartz.dll,10.00.19041.0329
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.19041.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.19041.0546
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.19041.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.19041.0329
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.19041.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.19041.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.19041.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.19041.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.19041.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.19041.0329
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.19041.0508
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.19041.0508
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0329
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0329
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.19041.0329
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.19041.0329
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.19041.0329
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.19041.0329
Audio Capture Sources:
Headset Microphone (Corsair HS70 Wireless Gaming Headset),0x00200000,0,0,qcap.dll,10.00.19041.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.19041.0488
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.0488
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.0488
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.19041.0329
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.19041.0329
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Corsair HS70 Wireless Gaming Headset,0x00200000,2,2,ksproxy.ax,10.00.19041.0001
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.19041.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.19041.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.19041.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Headset Earphone (Corsair HS70 Wireless Gaming Headset),0x00200000,1,0,quartz.dll,10.00.19041.0329
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.19041.0329
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.19041.0329
DirectSound: Q3279WG5B (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.19041.0329
DirectSound: Headset Earphone (Corsair HS70 Wireless Gaming Headset),0x00200000,1,0,quartz.dll,10.00.19041.0329
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.19041.0572
mfreadwrite.dll, 10.00.19041.0153
mfcaptureengine.dll, 10.00.19041.0546
mfsensorgroup.dll, 10.00.19041.0423
windows.media.dll, 10.00.19041.0546
frameserver.dll, 10.00.19041.0423
frameserverclient.dll, 10.00.19041.0423
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 27.21.0014.5751
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.19041.0572
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.19041.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.19041.0450
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.19041.0572
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.19041.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.19041.0450
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.19041.0329
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.19041.0001
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.19041.0001
WebpImageExtension
HEIFImageExtension
VP9VideoExtensionDecoder
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 27.21.0014.5751
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 27.21.0014.5751
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.19041.0001
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.19041.0001
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.19041.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.19041.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.19041.0001
HEIFImageExtension
VP9VideoExtensionEncoder
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.19041.0001
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.19041.0001
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.19041.0001
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.19041.0001
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.19041.0001
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.19041.0488
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.19041.0488
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.19041.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.19041.0508
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.19041.0423
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.19041.0572
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.19041.0572
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.19041.0508
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.19041.0001
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.19041.0207
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.19041.0423
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.19041.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.19041.0572
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.19041.0572
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.19041.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.19041.0001
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.19041.0572
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.19041.0001
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.19041.0001
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.19041.0001
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.19041.0572
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.19041.0153
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.19041.0508
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.19041.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.19041.0001
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.19041.0508
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.19041.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.19041.0001
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.19041.0001
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.19041.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.19041.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.19041.0572
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.19041.0572
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 1868382157751835337, type 5
Event Name: RADAR_PRE_LEAK_64
Response: Not available
Cab Id: 0
Problem signature:
P1: EpicGamesLauncher.exe
P2: 11.0.1.0
P3: 10.0.19042.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 127207764470, type 5
Event Name: VSSetup
Cab Id: 0
Problem signature:
P1: patch_KB3165756
P2: 14.0.25431.01
P3: 14.0.25431
P4: Install
P5: VCRedistD14x86
P6: Install
P7: 0x80070666
P8: unknown
P9: unknown
P10:
+++ WER2 +++:
Fault bucket , type 0
Event Name: VSSetup
Cab Id: 0
Problem signature:
P1: patch_KB3165756
P2: 14.0.25431.01
P3: 14.0.25431
P4: Install
P5: VCRedistD14x86
P6: Install
P7: 0x80070666
P8: unknown
P9: unknown
P10:
+++ WER3 +++:
Event Name: AppxDeploymentFailureBlue
Cab Id: 0
Problem signature:
P1: 800705B4
P2: 6
P3: 0
P4: NONE
P5: 10.0.19041.572
P6: 401
P7:
P8:
P9:
P10:
+++ WER4 +++:
Event Name: BlueScreen
Cab Id: 0
Problem signature:
P1: 74
P2: 2
P3: ffffa500977fca20
P4: 2
P5: ffffffffc000014c
P6: 10_0_19042
P7: 0_0
P8: 256_1
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: 74
P2: 2
P4: 2
P6: 10_0_19042
P7: 0_0
P8: 256_1
P9:
P10:
+++ WER6 +++:
No Data
+++ WER7 +++:
No Data
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
Latest BIOS?
Up-to-date drivers for graphics?
Tried taking one stick of RAM out and seeing if that's better? If not, take the other one out and put the first stick back in.
Boot into safe mode and see what happens? If that's fine then must be a driver issue or something, like antivirus interfering with Windows.
Chkdsk and sfc /scannow to check drive and Windows installation are OK?
Latest BIOS?
latest drivers, no overclocks, latest BIOS.
Its fine without this update.
