I've just put together a new build (specs below) and I get a horribly loud buzzing from the motherboard which I assume is the VRM's as it comes from around the top/left of the CPU socket.
Intel Core i9 10850K
ASUS ROG Strix Z490-F
EVGA SuperNOVA 850 G5
32gb Crucial Ballistix 3600Mhz
Samsung 970 EVO 1TB M.2-2280 PCIe 3.0 x4 NVMe SSD (x2)
GTX 1070ti
Here's a video of the sound:
The noise is barely audible at idle, but once you apply some load it becomes very loud. I have tried the following:
My gut feeling is I need to RMA the motherboard, before I tear it down I was wondering if anyone else has experienced the same problem and if you found the culprit to be a faulty board or something else?
GTX 1070ti
- Swapped to the PSU from my old PC, exactly the same problem (Coolermaster Silent Pro 850w)
- Removed the GPU, same noise
- I read some people resolved the issue by disabling C-State in the BIOS, made no difference
- Experimented with power options within windows, adjusting min processor state. No difference
- Unplugged all fans to ensures its not something silly!
