Major etailer.. they've been dropping them like crazy since last nightI mean MSRP is like 650 for a 3080, a grand seems a bit a lot -- also where did you find a 3060?
https://imgbb.com/My Gigabyte RTX3080 arrived about 40 mins ago. Installed and all is well finally.
Jesus these cards are huge.
I used to be able to put images here. But the host site I used no longer works. Any tips for what I can use. Thx.
I think you can attach a picture using the picture button. Not tried it, but it is the most obvious choice.
How I used to insert images appears not to be the case now. Confused. Have the link but no go.
I was a bit skeptical (hence my disclaimer), but thank you for trying. Not sure how other people are doing it.My Gigabyte RTX3080 arrived about 40 mins ago. Installed and all is well finally.
The embed code you need is 'BBCode'
Thx. No matter how I try, well in my phone anyway it won't work.
What queue number were you?Anyone confirm if 3080/90 orders fulfilled are getting COD Cold War codes? Just got my Tuf 3080 non oc shipping confirmation Yayyy.
Best thing to do is to log in and check your order status.''Thank you for your recent order with Overclockers UK, we apologise for any inconvenience caused but we have not been able to process your order as you have out of stock items on your order.
With further issues being experienced at UK Ports, we are moving ETAs on a daily basis, we are still expecting delivery Mid January 2021 but as mentioned this may change, we are sorry for the inconvenience that this may have caused.''
can some please tell me they haven't cancelled my order. having a panic attack rn cause of this
