Spec request: Good airflow with nice design
6 Jan 2013
Rollergirl
I'm looking for a new case. Criteria as below, and would be interested in any suggestions from those who have bought something similar and been impressed.
  • Looks good with windowed panel(s)
  • Great air flow
  • Accommodate a RTX3080
  • Accommodate Dark Rock Pro 4
  • ATX form factor
  • Budget £150
My vote would go for a Corsair 4000D (Mesh) or Lian Li Lancool II, they are under budget but that gives you room to add some nice fans of your choice should you feel the need:
My basket at Overclockers UK:
Total: £155.94 (includes shipping: £0.00)​
It does depend to an extent on what sort of connectivity you need.
Phanteks, Fractal Design, and CoolerMaster also have some excellent high airflow cases.
Good luck finding stock on anything right now though.
https://www.gamersnexus.net/hwreviews/3624-corsair-4000d-airflow-case-review-vs-solid-panel
The graphs in this review list both cases, as well as a bunch of others.
It's Phanteks I'm replacing as the air flow isn't great, but the build quality is excellent so yes if they've improved the air flow then that's definitely a contender. :)
Looks like it's going to be a wait into February at the earliest no matter what I go for... Who says PC gaming was dead!
Yeah, their older cases were quite restrictive. My old Evolv wasn't great but my Evolv X is superb for airflow, cannot fault it.
They made some massive changes to the front panel to increase airflow and it's great.
Which Phanteks are you replacing? It may be possible to replace the front panel on the one you have; e.g. the P400 solid front panel can be replaced with a Phanteks P400A mesh front panel sold separately on this very store.
It's the Enthoo Evolv. I need to move to ATX so will still buy something new but if there's a mesh panel available I'd use that in the meantime.
Ah, yes, I heard the cooling wasn't brilliant on that initial model. Sorry, I don't know of any pre-built replacement fronts for that model.
+1 vote for Lancool 2 - performance version if you can find it.
Build quality excellent and cable routing is very simple.
