My All New build Feels Like She LAUGHING At Me .Saying You Should've Gone Counsel
17 Nov 2008
my spec is
Ryzen 9 5950X
MSI MPG B550 GAMING EDGE
3070 eagle oc
Corsair 163301 Vengeance LPX 32 GB (2 x 16 GB)
Cooler Master MasterLiquid ML240R
Samsung 970 Evo 500GB
Aerocool Project 7 P750 RGB Full Modular 750W 80 Plus Platinum
Running all this set up straight out the box no XMP nothing overclocked Bios not touched after installing flash update Windows and all drivers fresh installed plus all updates.
I haven't gone more then 20mins without a complete loss of signal to the tv. sometimes I'm lucky to get out of windows login when pc loses signal fan still spin lights still on then bios comes up. It's not the ram or the PSU I swapped them around with my old working cases.
No idea what to do now there is the event viewer log. Cheers
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-WHEA-Logger" Guid="{c26c4f3c-3f66-4e99-8f8a-39405cfed220}" />
<EventID>18</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2020-12-16T10:10:01.9620168Z" />
<EventRecordID>1782</EventRecordID>
<Correlation ActivityID="{eab2b69e-89d9-4fa3-a143-89b8142f20e3}" />
<Execution ProcessID="3720" ThreadID="4536" />
<Channel>System</Channel>
<Computer>DESKTOP-OGEI8FR</Computer>
<Security UserID="S-1-5-19" />
</System>
- <EventData>
<Data Name="ErrorSource">3</Data>
<Data Name="ApicId">22</Data>
<Data Name="MCABank">5</Data>
<Data Name="MciStat">0xbea0000001000108</Data>
<Data Name="MciAddr">0x1fff803437227e9</Data>
<Data Name="MciMisc">0xd01a0ffe00000000</Data>
<Data Name="ErrorType">9</Data>
<Data Name="TransactionType">2</Data>
<Data Name="Participation">256</Data>
<Data Name="RequestType">0</Data>
<Data Name="MemorIO">256</Data>
<Data Name="MemHierarchyLvl">0</Data>
<Data Name="Timeout">256</Data>
<Data Name="OperationType">256</Data>
<Data Name="Channel">256</Data>
<Data Name="Length">936</Data>
<Data Name="RawData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ata>
</EventData>
</Event>
I was going to suggest the PSU, as Aerocool dont make decent PSUs (or anything else), have you check the temps of the CPU, and that your Liquid cooler is fitted correctly. have you tried another GPU, and have you got another PC you got try the GPU in
Have you tried all of the following from Microsoft website for that error:
Update the BIOS and the drivers for the motherboard chipset.
Update all the hardware drivers, if updates are available from your manufacturer.
Check the temperature inside the computer to make sure your processor and related peripherals are not overheating.
Check the fan on your CPU to make sure it is properly attached to the CPU.
If you have overclocked your CPU, reset your settings to the default settings.
Make sure you power supply fan is working correctly
The Aerocool P7 PSU is actually very good.
Temperatures seem to be running fine . At the moment I swapped out the 3070 eagle for a rx 5700. Running prime95 on blend CPU at 4.59ghz temperature is 49`C . With my old 5700 in seems to be running fine no reboots at the moment. Going to put 3700 in the old computer test the GPU. I don't know what software is good to test GPU. Cheers
My cpu is running at 99% using 3.35GHz now in prime95. Temperature 53 Celsius. The CPU seems to be fluctuating and temperatures every now and then. Is that how the program runs? Cheers
