- 17 Dec 2020
Hi all,
I recently built my first custom watercooled system which is also overclocked but I feel like my idle CPU temperatures (though idle is 4-5% CPU load due to things like iCue running in the background) are running a bit hot so I wondered if anyone could comment if 1) these are a bit warm and 2) any suggestions on what to do.
System:
- Ryzen 5950X overclocked to 4.6GHz on all cores using 1.285V vcore
- ASUS GeForce 3080 Strix OC with an additional 100Mhz OC applied
- Watercooling with Corsair kit for CPU / Radiators and EK waterblock for the GPU
- Running with 1x 360mm radiator (front-intake) with 3x 120mm fans and 1x 240mm rad with 2x 120mm fans (top mount - exhaust).
- Corsair 4000D Airflow
When the system is at idle the temps look as below in HWINFO:
CPU Section:
- CPU - 50c
- CPU Die - 48c
- CPU CCD1 - 44c
- CPU CCD2 - 36c
Motherboard:
- CPU Package - 50c
- CPU - 40c
The coolant temp at idle is running at around 30c and I have the fans / pump set to kick in fairly hard as the system goes above 30c.
When running Cinebench the system will sit steady at 75-80c on all the CPU measurements in HWINFO and shows 78 CPU Package in motherboard and 67 CPU in motherboard. The GPU in this situation sits down at
When running Cinebench and Furmark at the same time as a stress test - the CPU will get closer to or go slightly above 80c and the GPU hovers around 60c. The pump and fans kick in to high gear in this situation and the temps don't really go higher.
The above is all in a room that has an ambient temp of 20-22c.
Appreciate any feedback on whether this is what i can expect or if i should expect better? I'm fairly comfortable with the loaded temps - more questioning the idle and if there's anything i can do there.
David
System:
CPU Section:
- CPU - 50c
- CPU Die - 48c
- CPU CCD1 - 44c
- CPU CCD2 - 36c
Motherboard:
- CPU Package - 50c
- CPU - 40c
David
