Forza Horizon 4 Bench Thread
New Entry to the scoreboard-
Ryzen 5 3600x @4.2Ghz
Radeon 6900xt @ 2342/1950
ltmatt Reflection Quality is set to Extreme not Ultra.
not sure this has affect on scores?
Extreme is the highest setting.
I just checked your benchmarks and yours are not using the maximum settings as your reflection quality is only set to Ultra, so you might want to re-run at the correct settings. :)
**WHERE YOU AT TEAM RED**
1440p
GPU
177
MIN 151.3
177 — ~imgbb~
1080p
GPU - 212.4
MIN 182.5
212-4 — ~imgbb~ (~ibb.co~)
Stock aircooled stock thermal paste
MSI TrioX 3090 RTX @ ( 2145/10852 )
Intel 10900K @ 5.3GHz
457.51 Drivers
you might want to check the first post.
Kapp posted the 'correct settings' in the spoiler.
Fair enough. :)
@Kaapstad
It looks like the game was updated and added an extra quality setting moving from Ultra reflection to Extreme, which is one notch higher in quality.
Should i test again using Ultra? Probably easier than asking everyone else to re-run i guess. :p
3090FE @ 1935mhz - 10350mhz mem
5600x PBO 4850mhz
1440p
32GB
underclocked peak 250W. She is barley braking a sweat.
https://i.~ibb.co~/0Y4F64J/2020-12-19-4.png
thats 6900xt dispatched. with 50W less.
lets up the voltage and dispatch matt on average FPS, latency and minimum fps looks ok. :o
Latency looks good dontrocktheboat must be that single CCD?
what FCLK can you run? 1900MHz?
I returned my 5800x. might have a another play with a 5900x when they drop in price.
5600x PBO 4850mhz
1440p
32GB
Not bad, but i can beat that score drawing only 200W. ;)
Atm on 1900FCLK anything above gets a bit flakey tbh, and i cant reach the bios reset no more due to the size of the FE so I stopped there :o:D
Matt and his beastly 6800xt computer dispatched all under 300W
3090FE @ 2040mhz - 10350mhz mem
5600X PBO 4850.
1440p
32GB.
Book me a second place @Kaapstad
https://i.~ibb.co~/s54pX5G/2020-12-19-5.png
;) possibly, this one you will struggle with at under 300W. Still bested me in max.;)
Thanks to @FireTwo for the heads up on using the wrong settings, I was able to improve all my scores by lowering reflection quality to Ultra.
@Kaapstad Please update my scores, I will edit my old post and link to this post.
5950x PBO
6800 XT @ 2550Mhz / 2150Mhz
Adrenalin 12.2.2
1080P
1440P
@Dontrocktheboat Over to you, surely you should be able to beat these scores easily with a GPU costing £1400. ;)
Your score should be significantly higher.
I have been accepting Extreme for that setting as it is the higher setting.
The reason for the above is some people can not select the lower Ultra setting so running "Reflection Quality" at Extreme is only going to reduce their score.:)
Fair enough.
I can select both, so I'd rather use the settings as listed in the OP please. :)
