Paint bubbling after washing
20 Nov 2016
So I have just washed my car for the first time using Meguiars Ultimate Wash & Wax.
However I noticed the paint has bubbled in the area that was repaired 6 weeks ago/was repainted by an authorised manufacturer that came with an approved manufacturer guarantee, that gives no guidance in when you can wash your car/ points you to the owners manual on washing the car. Again no mention of do not wash your car for x period from new.
Obviously first of all annoyed, but thought I would take to the internet to understand if I've done something wrong?
https://ibb.co/JjJKyvV
https://ibb.co/8Y59q0G
Obviously remainder of car is unaffected.
You can push the bubbles like there is water underneath.
That just looks like a cack paint job to me. The last time I had some paintwork done I only waited a week before washing with my usual method.
I’d be taking that straight back to where it was painted and stressing the importance of proper prepwork.
It was fine until I washed it as far as I'm aware.
I just want comfort that they cannot say hmmm you should not have washed so soon after painting.
I've had cars painted before and never experienced this.
Totally fed up to be honest. The repair shop, took on the job of another repair centres **** ups/insurance rejection.
I have been without my car for 6months whilst this was all going on.
Already sent an email expressing my frustration, will see what's what Monday!
That orange peal effect was not there, and seems to have subsided since so not as bad as the pictures indicate four hours post washing
That paint is horrific, whoever did that should be embarrassed. It should go back to whoever painted it to be fixed. That's shocking.
That's a prep issue nothing to do with washing.
At the end of the day the only thing I would not recommend doing is coating a car until after a certain amount of time - this is to allow the car to gas but if the paint is baked this isn't an issue.
Simply washing or polishing a car is no issue though.
It was fine, I literally saw it start bubbling post wash
It's all grainy. You saying it had a mirror finish before being washed?
almost looks like micro blistering , prep is crap and washing wouldnt have caused it , looks like something contaminated the primer they used or a reaction, not sure i know there is experts here but possibly water in the primer (not dried out?)
yes - looks grainy as opposed to orange peal ... it's on a plastic bumper and also a body panel ?
? if you can move it with a finger nail, obviously needs a redo.
Had you powerwashed it ? albeit 6 weeks to cure sounds loads.
Washing would not have had any effect, unless you are using neat tfr or something totally unsuitable for paintwork like jif.
When I painted cars they'd always be washed as the final step to returning them,
prep
paint
bake
finish (sand, cut, polish as required)
wash due to the above)
detail
handover
This is poor prep and a reaction in the paint layers.
Literally misting it with jet wash for obvious concerns with the paint being new.
Jet was not reaching the back bumper too well so at at good distance.
prep
paint
bake
detail
handover
Hoping it will be an easy convo with the company Monday.
It has a transferable guarantee on the repair work completed by the manufacturer. I received the paperwork via email
Don't even mention the washing or complicate things just take it back and ask them if they would be happy with this paint job ?
Had better results straight out a £3 can and I'm terrible at spraying !
if that's the area they repaired, have they also fitted the parking sensor wrong? It surely shouldn't be pushed in like that.
As others above - that looks to me like it was like that from the moment they painted it, and you just haven't spotted it until after you washed it because that's when you look really closely.
No you're right it doesn't look at all correct.
