19 Dec 2020 at 16:06 #1 Vakas Vakas Associate Joined 8 Apr 2009 Posts 1,891 Location Manchester I don't really use it much these days but is there a free piece of software that is good for burning CD's?
19 Dec 2020 at 16:11 #2 Haze Haze Soldato Joined 10 Jan 2007 Posts 5,121 Location Warwickshire BRB, will type it into Google for you....
19 Dec 2020 at 16:44 #3 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,891 Location Manchester I can Google is but I wanted some good suggestions so that's not the point
19 Dec 2020 at 22:27 #4 Ninco! Ninco! Associate Joined 8 Jul 2014 Posts 2,435 Location Hampshire There is an ongoing discussion in the Optical Sub forum
20 Dec 2020 at 02:02 #5 MrPleasant_exe MrPleasant_exe Associate Joined 21 Mar 2016 Posts 116 Christ, discs in 2020 lol
20 Dec 2020 at 04:22 #6 Haze Haze Soldato Joined 10 Jan 2007 Posts 5,121 Location Warwickshire Vakas said: I can Google is but I wanted some good suggestions so that's not the point Click to expand... You want a free one.... Its like you are going to be spending money, so want to avoid wasting money on the wrong one..... Open a search engine and look for reviews, and then download one or two and see which ones suits your needs the best
20 Dec 2020 at 12:35 #7 smogsy smogsy Soldato Joined 9 Dec 2006 Posts 9,330 Location @ManCave foobar has this support
20 Dec 2020 at 12:37 #8 scrivz69 scrivz69 Soldato Joined 6 Dec 2008 Posts 2,873 Location York https://cdburnerxp.se/en/home
20 Dec 2020 at 12:49 #9 Paul11 Paul11 Soldato Joined 28 Sep 2003 Posts 10,407 Location London even itunes is good at burning discs
20 Dec 2020 at 15:20 #10 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,891 Location Manchester Just downloaded cd burner, thanks guys
20 Dec 2020 at 23:02 #11 Django x2 Django x2 Soldato Joined 28 Sep 2008 Posts 14,308 Location Britain Vakas said: I don't really use it much these days but is there a free piece of software that is good for burning CD's? Click to expand... Yep. It's called Windows 10
