Great the low FPS thing and low res graphics is back on series x.
what a useless bunch of *****
Getting this, it's absolutely rubbish. Also frame lagging, low FPS . Ridiculous
I figured out a way for mine to go away when it happens. While COD is "running" / in the menu screen, just go to the Xbox dashboard, flick through a couple of menus, then bring COD back into focus.
I haven't had the low fps issue since season pass update. Nor any other issues at all (touch wood)
With the xbox itself though - yesterday decided at one point to refuse to connect to wireless controller. Had to force full shutdown.
Enjoyed a lot of nuketown holiday yesterday with bullfrog.
I had something similar caused by my wireless headset, I have the Arctis 9X which uses the native Xbox system to connect as a controller would. Fixed by the firmware update for the headset.
Only just got the email. Does take some finding wow 93GBFree MP for a week, if you download the trial version which is a bit hidden away in the store.
I get this sometimes but if I press the Xbox button on the controller and go back it's fine.
How did you update the headset? Was it via steel engine 3? I'm trying to do it on an iMac but it won't see it.I had something similar caused by my wireless headset, I have the Arctis 9X which uses the native Xbox system to connect as a controller would. Fixed by the firmware update for the headset.
