As title - it doesn't even seem to be at 3.7ghz, it's just at 3.6 Ghz and won't boost when the CPU is under load. I've tried with Prime95 and OCCT to load the CPU to see if boost activates, but nothing. I've loaded the default settings in the BIOS, as well as trying with PBO enabled or disabled. XMP profile is activated and RAM is running at the correct settings.
When I enabled Game Boost (PBO) in the BIOS, it changes the CPU speed to 4200 Mhz and vcore around 1.332, but when I get into Windows, all programs I use to check speeds show it as 3.6 Ghz.
Any thoughts? Cheers
Ryzen 5600x + MSI B550 Tomahawk
Thanks again for the help
