I have a conundrum about where to take our ageing Fileserver and Domain server.
Facts:
It wouldn't be the end of the world if the TS went down as i plan to move to local machines for each user.
As i have not used Azure for files or domains just wondering if there are any pitfalls or alternatives?
Thanks in advance!
			Facts:
- Server is a HP G6 Intel Xeon X5670 with two processors and 96gb RAM, this has a terminal server, domain server and storage on it.
 - Storage space is becoming an issue
 - TS users = 8 max with 4/5 concurrent.
 - All employees use O365
 - Some employees use Sage Line 50 using Sage Drive
 - We currently have two sites one in Leicester and one in Newcastle, not connected by VPN.
 - We have a decent connection speeds although our HO is on radio broadband, we get 500mb up and down.
 - Our HO router (peplink) has a flaky VPN setup so we called time on that.
- Move the FS (currently around 0.9TB of data) to Azure cloud
 - Move the DS to Azure AD
 - Install a Synology box at HO for local copy of Azure
 - Use Synology VM for install of Win 10 to run Sage Line 50 file server app that is required.
 - Use spare Buffalo NAS for local copy of Azure files at Newcastle site
 - Install shared drives on all local users connecting to the FS on Azure
 - Install new Windows Server 2019 on HP G6 solely to run as a TS at HO.
Thanks in advance!
  Azure is good but you going to pay heavily for that service.  Make sure you work out exact costs cos if you don't you going to get bitten hard.
  Maybe a re-auth could be done by a batch script so it's easy for them to click on it.
