Sorry guys...no its didnt survive, I didnt actually try until Saturday as I replaced it immediately with a 3800XT and waited for AMD to respond to a warranty request which was refused.
I used a mechanical pencil and everything was ok until the last 2 pins, both of which snapped off completely.
Thats the 2 most bent ones on the right hand side of the picture. I guess some soldering guru could retrieve it but I dont have the kit and its probably not worth the investment now.
You still got it? Are the two snapped pins right at the edge?
Just sell it on ebay, there are many people that can get that working again, the pins can even be purchased and soldered or using a dead cpus pins to replace the broken ones. Stick it on a bids on there and see what they offer, just explain it was working and the boo boo that happened and should get sold.
One is, the other one is one pin in.
Good idea! I'll do that now.
Did you try it to see if it worked without the 2 pins?
.No I didnt, that would have meant removing my new 3800XT and the last time I tried to remove an AMD CPU it didnt end well..
intel socket is much better design tbh holds it down, and i like the pinless chips.
just need to be very careful of the mobo pins
Agreed. This post now has me worried about upgrading my 1700 to a 5900x when zen 4 comes out. Even if the 1700 isn't worth a lot by then.
