Corsair Vengence LPX3600 / Asus Prime B550/ 3600X - is this right??
28 Mar 2006
South Glos
Hi guys,
So I have just got this setup and I am not sure if the memory is configured correctly?
The memory is CMK16GX4M2D3600C18
Memory is in slots A2 and B2. DOCP is set to profile 1 which gives DDR4-3597 18-22-22-42-1.35v, which matches what is listed on the corsair site for this memory.
All other memory options in bios are set to Auto.
CPUZ gives me this:
Is this right?? I'm sure the cpuz bench is not the best out there but the numbers do look a little low compared to a 1700x?
Also the DRAM frequency looks a little low too right???
Thanks in advance gents :)
Did it have problems booting after you did that? It's weird because the timings are correct, but the frequency is stock (2133).
you havent enabled XMP of DOCP for the ram in BIOS. it is running stock speed which is 1066Mhz
I did set DOCP and the bios seemed quite happy that it was running at 3600 with DDR4-3597 18-22-22-42-1.35v but in Windows it would give me the results in my op.
Nope, booted fine.
I went back into the bios to double check things and in the end set back to detaults with DOCP off and then reapplied them.. Seems to be looking better now, and in system performance displays as 3600mhz.
Is this looking more like it??
Thanks for you help both :)
