Got my maintenance order in. Couple of 105 cassettes (turbo and road) a Red chain and some chamois cream.
Planning to wax my chains, for quieter running and cleaner on the turbo, and for hopefully less/easier upkeep and reduced wear overall.
I bought the molten speed wax to try and a small slow cooker. Not convinced by the DIY waxes, without any testing there are too many uncertainties, but I wasn’t springing for the new Silca wax or the UFO expensive stuff just yet.
Stock seems to be dwindling and Brexit uncertainty cutting off the German websites. I was holding out for a discount code but none seemed to appear and the cost was as cheap as I had seen since the start of Dec no change.
Prep of the chains before waxing is more important!
Degrease for 24 hours and then ultrasonic bath. Dry for 24 hours and then MSW in the cooker.
If you do it properly, you will be VERY impressed and never go back to cave man lubes
