Hi, just trying to get my build started got everything plugged in and when I try and flash the bios it just powers up after a few second the easy debug led for the cpu white one stays a solid white and the system just runs, there is no light from the led next to the bios flash button.
Need to do it this way as I have a 5600x.
Any thoughts of where it's gone wrong.
My usb stick has been slow formatted and quick formatted several times in Fat32 and I've taken the bios file and renamed it MSI.COM and put it on the usb stick.
I've tried resetting the bios but not sure what the instructions are telling me to do.
Thanks for your time.
So the big mistake I made was installing everything before flashing the bios, this basically just turned the computer on when I pressed the flash button instead of flashing the bios. This just lead to the RGB and fans turning on and the white debug led being a solid white.
