- 3 Mar 2015
- Wokingham
I loaded this M2 into the first M2 slot on this mobo. This Sabrint does not come with a screw to pin-down its 'far/loose' end to the riser provided on the board. They say that the Mobo vendor should provide it. MSI do not provide it, though.
It's not entirely needed; the mobo provided heatsink will still push down onto it. However, in case perfection is sought, I can confirm that an old Xbox controller (T9 torx) screw fits instead.
A good PC engineer will always recover screws and bits off old gear before chucking away. After 30 years of this I have hoarded a veritable mountain of odd stuff which occasionally can be of use!
