They do not last long. I got really luckyI've actually never seen it in stock there but I guess an additional £110 isn't overly bad, atleast it wasn't a scalper.
That is exaggerated nonsense as the vast majority of programs I use for work and hobbies outside of gaming can not fully utilise more than 8 cores or threads.Okay but Intel is stopping at 8 cores so it's basically useless for anything other than gaming...
You should be aware that even asking can lead to a suspension.£750? Where? I had to pay £860! Lol.
Well you're a sack of interesting fun aren't you? And I don't particularly care if you personally can or cannot utilise cores outside of your very small use case of a computer.That is exaggerated nonsense as the vast majority of programs I use for work and hobbies outside of gaming can not fully utilise more than 8 cores or threads.
No, they'll be poor value compared to the 5800X, which is all they're really competing against with their lousy 8 cores.
And these are the ones intel tended to win.
I've already said I'm not interested in 1080p benchmarks. I only mentioned them because a couple of people here have latched on to them for some reason.
1080P benches are widely abused to show a difference between CPUs that is simply not important in the real world, that's the reason.
Whether I am or fun or not has nothing to do with the simple fact you were spewing exaggerated nonsense when you said...Well you're a sack of interesting fun aren't you? And I don't particularly care if you personally can or cannot utilise cores outside of your very small use case of a computer.
16 cores for £750-850 is a lot better value than probably, knowing Intel, 8 cores for £500 with security flaws, patches and more that will mitigate performance furthermore and consume probably an easy 300W+.
Bet new year's was a joy with you lad.
No they don't. Stop making stuff up. Do you use the programs in question or are you just going to post up benchmarks and charts that have no bearing whatsoever on my point - why on earth are you posting up a fully threaded benchmark?These programmes need Ryzen fixes / patches in order to get the performance right.
I can see you are also a photographer as you have a Canon EOS R5 (nice camera). This is a list of some of the photographic software that I use that unless in batch mode rarely uses more than 8 cores. You might use some yourself. In all of them my 8 core Intel 9700K is faster than my 16 core 3950x, when just using the CPU (and not GPU where possible).
Adobe Photoshop
Adobe Lightroom
DX0 Photolab
Nik Tools
ON1
Topaz Gigapixel
Topaz Denoise
PIPP
RegiStax 6
Sequator
AutoStakkert
The simple fact, whether you acknowledge it or not, is that the vast majority of software outside of video and rendering etc can not take full advantage of more than 8 cores.
Adding the obvious truism to your statement, that Ryzen is still much better value, doesn't negate the nonsense of your previous statement.
I see it might be a while before you reply with more of your puerile quips as you failed to heed my advice and got yourself suspended. Ah well...
This may well be case though my 9700K is at 5.3Ghz with tuned RAM at DDR4000 CAS15.Almost all the programs you listed can benefit from more cores or higher IPC. Currently, the fastest cpu for almost all those are the AMD Ryzen 7 5800X, Ryzen 9 5900X, and Ryzen 9 5950X. Unless a program has been specifically optimized for Intel then most of the time AMD higher IPC and core count will perform better. I not going to sit here and list a ton of benchmark charts and/or debate it. Just stating facts.
I should be getting a 5800X before the end of the month (the 5000 series bios for my motherboard is finally out) and I will be testing it for myself. I'm expecting a tuned 5800X to be faster than my tuned [email protected] but I'd like to see by how much for myself - benchmarks often don't give me the full picture for my setups.
Number of cores is irrevelant. Performance for your use case is all that matters.
So what if they were the ones intel tended to win? I've already said I'm not interested in 1080p benchmarks. I only mentioned them because a couple of people here have latched on to them for some reason.
Sure, and unless your use case is "current games that don't scale to all cores very well", then 8C is not going to cut it, performance-wise. Mine (general use, software development, AI/ML experimentation, cryptography and crypto-cracking) will of course see even more benefit.
You're right that core count is not that interesting on its own, 64 Pentium 2 cores at 233MHz wouldn't match up to a single modern i7 core. But when the individual cores are performing more or less the same within a couple of percent, as AMD and intel are at present, then having more adds up to a more capable chip. As a result the upcoming i9 is competing with the 5800X, not any of the higher core parts.
Intel's "best for gaming" line was largely based on these unrealistic benchmarks, that's why people keep bringing it up.
I don't think games will scale past 8 cores (16 threads) in any meaningful way even in the lifetime of new platforms due next year.
But Intel was best for gaming.
Yes that is the case as then those can be done in batches which takes advantage of the extra cores.Yes true. Also having O/C and tuned system changes numbers. I will say that having a high number of cores (8+) typically only helps with tasks like exporting and generating. The CPU speed and architecture makes a bigger impact than the raw number of cores.
Adobe Photoshop
Adobe Lightroom
DX0 Photolab
Nik Tools
ON1
Topaz Gigapixel
Topaz Denoise
PIPP
RegiStax 6
Sequator
AutoStakkert
