Built a new system recently spec below, was running fine with the original cpu a 3100 but since swapping to a 3800x, apex legends will crash/close randomly sometimes it happens seconds after launching, most of the time it crashes while playing the game longest its went before crash is 20 minutes usualy crashes in first 5 minutes
corsair tx750m
3800x previously 3100
artic freezer 34 esports duo
Msi b550 gaming carbon
Ballistix 2x8gb cl16 basic ones
wd blue nvme ssd sn550 1tb
Sapphire rx480 8gb
cooler master mb520 argb
The system has never froze bsod or restarted just apex freezes the sound stutters of a sec then plays for 10 second then i am back on desktop, can still play battlefield 1/5 fine.
apex doesnt create a crash file and there is nothing in event viewer to give me any clues.
so far ran prime95 for 30mins no errors, occt 30mins no errors, removed cpu inspected reinserted. All the temps are fine nothing is overheating all the psu voltages look fine in hwinfo. tried running with memory at default speeds and core boost turned off, formated drive and reinstalled win 10.
Fairly stumped as to the source of the problem.
Thanks
lewis
			corsair tx750m
Sapphire rx480 8gb
Thanks
lewis
