How to tell if you have a failing PSU?
26 Jan 2010
Had a few BSOD on cyber punk and just cyber punk
Most ppl on the steam forums state that its my PSU that is dying, apparently during some situations ingame, hard render scenes, apparently my PSU cannot handle it
I own a 1300 watt Evga G2
Nothing else causes BSOD, not sure if I should underclock my GPU
Especially at a time where there is a PSU drought, hardly any stock anywhere.
Wondering if there is a way to actually test the PSU to determine if there is a fault.....
Cub6yer punk is plaughed with problems and of its only happing in that game then theres the problem and its seriously demanding.
A 1300w psu will handle any gpu.
What gpu you got, is it maxing out at 100% what fps you getting in cyberpunk.?
ive got a 3080 Evga FTW ultra at stock speed, on a 1440p screen im getting around 60-90fps depending on the map, and the usage shows 100%
Im not convinced its the psu as the game is buggy , have you got individual pcie cables connected to the 3080 ?
well its a 3x8 pin connection on he gpu, ive got a 8 pin single connector going from the PSU to the GPU x3, so no daisy chaining.
I have a AE9 connected which also hasits own 6 pin cable from the PSU
Ive also got 4 HDDs and 2 SSD's, but i still have 4 empty connections on the PSU so im not drawing full load, it is however 4-5 years old
But EVGA PSU's are kind of bullet proof, never had any issues.
Do u think it could be hardware related such as the motherboard? 2077 is a mess of a game however im told BSOD is a hardware issue?
You could See of there's a bios update for your 3080 but that fact its only happening in cyberpunk seems umits game releated.
Tone down the detail in game to increase fps then lock the frame rate to 60fps see if crashes still occur.
Have you checked windows event after crashes ?
Take down off any overclocks you may have running, and disable any overlays. drop your gpu clock speed down 100mhz and see if it's doing ok. That's normally the method I use to diagnose any random crashes I get during a heavy game
