- 3 Oct 2007
- London, UK
EDIT: DON'T INSTALL F20 BIOS!! PROBLEMS WITH 10TH GEN CPU
Just noticed a new bios is out with resizable BAR now an option. I've installed, it took far longer than any previous bios took and the PC rebooted 10 times before I finally got to splash screen and bios. Have been able to turn on adjustable BAR. Not sure if it is working, will have to test the 2 different bios against each I guess and see if there is a FPS improvement. I do have a 3080 so I'm guessing it should work?
https://www.gigabyte.com/Motherboard/Z490-AORUS-MASTER-rev-1x/support#support-dl-bios
Edit: I probably should have read their page fully
There was a BAR update for 10th Gen, F8. F20 is 11th Gen. Still it works and so far no problems.
