- 6 Jan 2021
Morning all!
Hope you're well. I recently received my new Ryzen 9 5900x and had nothing but problems to start with! Multiple reboots with WHEA Uncorrectable Errors, Cache Hierarchy errors etc, even the DOCP settings meant I couldn't POST so had to clear the CMOS and start over! I was able to run Prime95 for 2 hours in amongst the madness with no issues, but when I tried to load up Call of Duty Warzone, the PC would just reboot with no BSOD. It seems this issue is all over the web so I figure it can't be faulty hardware, right?
That being said, I have since updated the BIOS of my ASUS Prime X570-P mobo to the latest Beta version, re-applied the DOCP and touch wood, everything has been stable so far. I've even been able to apply the DOCP profile now.
I don't know whether I'm worrying too much, but I don't like seeing the CPU hit 80 degrees when gaming. I don't know whether this is OK or not, as I'm still relatively new to PC building (this is my 2nd, looking to run a dual PC streaming setup!) I have left everything as default so far but my average voltages under load are about 1.45v. I can cap this via Ryzen Master but i have to do this every time i start the PC.
Would you recommend under volting slightly in the BIOS to reduce temps a bit? Or could this have an issue when trying to reach higher clock speeds? Should i also have Core Performance Boost and Precision Boost Overdrive enabled? Temps seem to average around 65-70ish when gaming but spike to a max 83 every now and then.
Sorry to ramble on, any advice or information would be greatly appreciated.
Many thanks,
Alex
Many thanks,
Alex
