Power connectors to a 3070?
7 Dec 2002
UK
I'm considering getting an RTX3070 when stock levels (and prices) aren't so ****.
However i'd rather not get a new PSU, i have a Corsair 750w at the moment however it only has multiple 6 pin GPU connectors & i believe the RTX has an 8pin?
Can I use some kind of adapter?
What PSU is it? Are you sure it doesn't have 6+2? It would have to be way old not to.
It's a Corsair PSU, CX750 I think, it does have multiple 6 pin connectors, either 2 or 4, unsure without pulling the case out from where it resides & taking the side off.
EDIT - Ok, i think my problem is solved, it appears the 6pin connectors have another 2 pin part attached, i presume this is the 8pins I need on the 3070?
That will have 6+2 connectors so will be fine. Just use 2 different power cables for the GPU.
Result!
