Spec me a new case
23 Nov 2009
North Leicestershire
Really want to change out my case currently have the phanteks enthoo primo full tower
https://www.overclockers.co.uk/phan...MIpNLqkO6b7gIVgdPtCh3gmAVjEAQYASABEgJuI_D_BwE
New case must be black and be able to hold 2x 480mm rads comfortably as I will be re using most of my old kit and be no more than 650mm tall. Run a m.2 2x ssd and a mech storage drive. No real budget in mind but nothing that's over £600 ideally
Thanks
Thanks
Maybe Lian Li O11 dynamic https://www.overclockers.co.uk/lian-li-pc-o11-dynamic-midi-tower-black-window-ca-76s-ll.html
Why will I struggle? Is it the 2x 480 rad support? That case looks nice and clean but in pretty sure I won't get a 480 in the front and top at the same time.
The Fractal does state it has room for 4x 120mm fans both at the top and front. I am just unsure if radiators would overlap at any point. Best to look for reviews online to answer that.
Cases that support 2x480mm will be on the rarer side, with 360mm rad support much more common.
I didn't search for too long, but only found this and the case you already have to in theory fit the spec. The Lian Li O11 Dynamic, even in XL, doesn't have the 480mm support.
Still searching for that elusive case that fits the bill. Wife won't let me change desk or location so stuck with 650mm height clearance
