I have noticed that my 2007 Civic 1.8 petrol is not returning to idle very smoothly.
If i rev it, revs will drop as normal till about 1000-1500 rpm where they will then slightly rise again (in spite of my foot being fully off the throttle), and then they will return to the normal 700rpm.
This happens pretty consistently, and i think may be the reason why i have thought it has been a little jerky when coming off the throttle at low speed.
So essentially, i can be sitting at idle, rev the engine, foot of throttle, rpms drop as expected until 1000-1500rpm where the drop will then slow, and there will be a small little increase/rev (done by the car , not me), and then they will go down to proper idle rpms.
When back down, the idle is smooth and at the correct rpms with no issues.
Also, it happens in gear, out of gear, in neutral, clutch in or out etc so its definitely engine related.
There are no warning lights/engine lights and the car otherwise runs fine.
Any thoughts?
My first thoughts are either somehitng is sticking throttle wise, or there maybe a small hose/air leak somewhere. However if there was an air leak, would it really idle so well once it is there?
Any thoughts?
