The Ventus aren't dead, we are still getting them in small numbers but as I said earlier in this enormous thread, the Ventus card is MSI's system integration model. A couple of generations ago it was SI exclusive and much of the stock that we've received has been designated for our SI business (even that isn't a lot). However, because MSI aren't a focus brand for my SI business I'm able to give some stock to Gibbo at times. I was given a whopping 20pcs last month of which I was able to give 7 to those in the retail queue.
Food For thought
There are major SI's, bigger than OcUK who DO focus on MSI, in fact MSI is the core of their business and MSI rely on that business for a lot of their volume every year. So, who do you think MSI are most likely to give their Ventus cards to?
This is not a criticism of MSI, we rely on similar relationships with other brands, it's just business.
In fact, if you take it back as far as manufacturing. Say MSI are given 1000 GPU and 200 are allocated by Nvidia for the SI sector, most, if not all of which will be turned into Ventus cards. That leaves 800 for retail. If they put them on Ventus PCB they would probably make less money than if they put them on Trio PCB, so, when it comes down to splitting the retail allocation, which way do you think they might lean? This is purely hypothetical. We're not privy to this information but it's worth thinking about as it would explain a lot.
