New Build Randomly Shutting Down
31 Mar 2010
So I've recently put together a new build
Case: Ncase M1
Motherboard: Asus ROG Strix B550-i Gaming
CPU: 3700x
GPU: RTX 3080
RAM: Team Group 8Pack Edition 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz set to XMP
PSU: Tried Silverstone SX650g (returned) and Corsair SF750 (current)
The above build seems to be on occasion shutting down seemingly at random. It's not very frequent (maybe once or twice a day) and hasn't happened so far when gaming / under load. It's an instant hard shutdown after which the PC boots pack up.
I used the RAM and CPU in my old ATX build without issue.
It's occurred on both PSUs I've used, updating the BIOS didn't fix it, and the RAM has been reseated. Any ideas what it might be / what I could do to diagnose?
12 Jan 2021
Some people report that AMD motherboards can be a bit fuzzy with the ram. You could try disabling XMP to see if this solves the issue as one option to try, it worked for me on one Gigabyte board
OP
31 Mar 2010
My old motherboard was totally fine but I hadn't ruled it out. It would be really annoying to be stuck with ram at stock though.
Check Windows sleep/hibernate .settings.
Is it likely to be this if it shuts down even while I'm using the PC?
OP
31 Mar 2010
Anything showing in event viewer around the kernel power critical error?.
Just got back from a walk and it looks like it's done it again while I was out. There's a couple of interesting sounding events in the log, including a kernal power critical error:
Log Name: System
Source: EventLog
Date: 17/01/2021 15:04:43
Event ID: 6008
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Simon-PC
Description:
The previous system shutdown at 14:37:20 on ‎17/‎01/‎2021 was unexpected.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-01-17T15:04:43.9104679Z" />
<EventRecordID>45708</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>Simon-PC</Computer>
<Security />
</System>
<EventData>
<Data>14:37:20</Data>
<Data>‎17/‎01/‎2021</Data>
<Data>
</Data>
<Data>
</Data>
<Data>163861</Data>
<Data>
</Data>
<Data>
</Data>
<Binary>E5070100000011000E00250014000600E5070100000011000E00250014000600600900003C000000010000006009000001000000B004000001000000FEFFFFFF</Binary>
</EventData>
</Event>
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 17/01/2021 15:04:39
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: Simon-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2021-01-17T15:04:39.5162453Z" />
<EventRecordID>45721</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">3</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
58 Copies of the below Warning.
Log Name: System
Source: Microsoft-Windows-WHEA-Logger
Date: 17/01/2021 15:04:00
Event ID: 19
Task Category: None
Level: Warning
Keywords:
User: LOCAL SERVICE
Computer: Simon-PC
Description: A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Unknown Error Source
Error Type: No Error
Processor APIC ID: 0
The details view of this entry contains further information.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-WHEA-Logger" Guid="{c26c4f3c-3f66-4e99-8f8a-39405cfed220}" />
<EventID>19</EventID>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2021-01-17T15:04:00.2679625Z" />
<EventRecordID>45696</EventRecordID>
<Correlation ActivityID="{d24f2c9c-63c0-4066-9a22-6dc029e7ec6b}" />
<Execution ProcessID="4252" ThreadID="9380" />
<Security UserID="S-1-5-19" />
</System>
<EventData>
<Data Name="ErrorSource">0</Data>
<Data Name="ApicId">0</Data>
<Data Name="MCABank">25</Data>
<Data Name="MciStat">0x98004000003e0000</Data>
<Data Name="MciAddr">0x0</Data>
<Data Name="MciMisc">0xd01a0ffe00000000</Data>
<Data Name="ErrorType">0</Data>
<Data Name="TransactionType">256</Data>
<Data Name="Participation">256</Data>
<Data Name="RequestType">256</Data>
<Data Name="MemorIO">256</Data>
<Data Name="MemHierarchyLvl">256</Data>
<Data Name="Timeout">256</Data>
<Data Name="OperationType">256</Data>
<Data Name="Channel">256</Data>
<Data Name="Length">872</Data>
<Data Name="RawData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ata>
</EventData>
</Event>
The next warning is from 13:58:11 so before the crash if the 15:04:43 error is to be believes.
15 Oct 2019
Uk
The WHEA error would most likey be the culprit for the restarts.
Try lowering FCLK to 1600 and ram to 3200 and see if that stops the crashes.
