Why only two gang plug sockets in the UK?
Even just the socket next to my bed has 8 plugs :(
Heated blanket left side
Heated blanket Right side
Wireless Phone charger
Wireless Smart Watch charger
Harmony remote control dock charger
Alarm Clock
Bed side Lamp
Battery charger for my torches 18650 batteries
The Plug sockets behind my AV stand has these
TV
4K AppleTV
HTPC
Skybox
PS4
Xbox one X
AV Amp
Subwoofer
Harmony remote Hub
Network Hub
Wireless keyboard charging dock
Philips Hue Bridge
Electric panel Heater
Cordless B&D Vacuum cleaner
I haven't counted them lately but if i remember right i used to have close to 30 things plugged in just one room
Most of those are low powered, and should function fine on a single 13amp extension.
the current sitch
This can't be better than having them inset into the wall. Or perhaps it is because I can always move them.
why is that extension upside down putting strain on the cables? seems unnecessary. Also, what would more wall sockets achieve? You're still going to have stuff plugged in to sockets, only now it'll be sockets mounted, presumably, 45cm up the wall instead if the regs apply. What are you actually gaining?
A spur off a spur is like extension leads plugged into each other.
A ring main is on the ring and so in theory half the load down each wire. Much safer
Spur off a spur isnt allowed unless it is initially protected by a 13a FCU anyway.
There is nothing wrong with an extension lead if used correctly :confused:
Lots of people do put in 3x2 gang sockets behind their TV as part of the ring main but that’s mainly for looks and has little to do with safety.
Plugging an extension lead into another isn't the same as 6 sockets sharing a busbar on the ring main.
Obviously it depends on the overall power load if its safe or not.
Most are just spurs into fcu then you can chain as many sockets as you need. Very few will be extending the ring.
