Is there anywhere that actually states enabling BAR/SAM will worsen performance with evidence to back it up?
As given how the tech. works, in theory it should actually benefit ALL gpus. From my understanding, it simply is eliminating a bottleneck where we had to rely on like a temporary swap system, where only up 256MB chunks could be swapped out each time, where as now, it is direct access to VRAM so almost like removing the middle man and allowing a bi-directional direct transfer rather than a limited uni-directional transfer system.
Plus, don't forget consoles have 16GB VRAM/RAM overall, nothing else and suspect this is where BAR/SAM is helping them so it should help PCs game ports too.
EDIT:
Having a quick read on reddit, so if CPU can only access the VRAM with this bar/sam feature enabled i.e. is limited to purely whatever VRAM said card has, then it could potentially have an impact.
Hard to say though.....
EDIT:
https://hardwaresfera.com/en/articulos/resizable-bar/
Yup I don't see how having a low amount of VRAM is going to be a disadvantage, maybe with 8gb and less at likes of 4k/4k texture packs etc.???
EDIT:
someone's take from reddit:
So all in all, those cards with more vram might see more benefit but ultimately, other cards with less vram will also see benefit, just not as much.
There are so many factors but utlimately Resizable BAR enables future optimisations, as will MS Direct Storage. As the tech becomes more mainstream (people upgrade to newer hardware), developers can optimise the game files to better support this technology e.g. multiple smaller game files with higher compression as your system will be able to a) decompress faster and b) swap files on demand given the higher throughput.
Obviously depends on the resolution that you play at and the size of the game files, but PC gamers have the benefit of developers needing to cater for consoles. I fully support slimmed down tech as a result of software and architecture improvements - this will ultimately lower the cost and production effort, which benefits everyone involved.
