UPS batteries req.. for CyberPower CP1300EPFCLCD (RBP0124)
Looks like two "taped together" standard 7Ah 12V batteries, which is the most commonly used sealed lead acid battery and should be available from any electronics component store.
That ready battery pack probably costs lot more than getting separate batteries and packing them yourself.
[ edit ]
OK I checked the battery inside them is 2 x BB Battery CPS7-12.
It doesn't list the maH, but says: 12V, 27WPC/15 min/1.30VPC/25c
Measuring I get:
Height 103mm x 90mm length (wide) x 70.2mm width (thick)
Terminal F2 width 6.3 mm
I cant find these BB batterys for sale anywhere in the UK. Anyone knows what the best equivalent ?
If anyone comes across this thread:
I managed to fix it by finding these batterys: CSB HR 1227W F2 Battery 12v 27w
The 27w ones are the best for this UPS.
Is easy to replace the batteries?
Did you bought two of :
How did you connect them together ?
Have you used the "central part" of the original battery pack ?
Thank you,
Salvo
Thank you,
Salvo
Sorry for late reply, yeah it was easy to replace. Just connect them the same way you pull them out of it. Reuse the tape (thats the central part your talking about I presume).
The tape is stick enough and strong enough to be reused. Mine are still going strong. Oh make sure the batterys have F2 terminals.
Thank you for your feedback.
In your opinion, is there enough space to put inside the "classic" 2x 12V 7Ah ?
I saw that the case size is the same of CP1500 (maybe is a website mistake)
CP1300
CP1500
The CP1500 uses the RBP0016...
What do you think ?
Its not the case you should be worrying about, its the battery compartment.
Did you pull out the old batterys ? They will be just 2 batterys taped together. Measure them as they could be slightly different in your version.
I don't have it. I'm wondering if I should buy it.
Since I noticed that the UPSs case size are the same, I'm asking if I'll have problems on find batteries.
It is a tight fit and there not much choice at 12v and with 27w capacity. CSB ones are good quality and match the originals.
