55-60" TV recommendations needed
18 Jan 2007
Dorset
My trusty Sony 55" has just died! It lasted over 6 years, so had a good innings.
Need a replacement, reasonably quickly, with the following requirements:
Between 55" and 60" (Try as I might, can't get permission to go bigger:()
Min of 4 x HDMI
Max budget of £650
Built in Google assistant would be nice, but not essential.
Home delivery!
I'm totally out of touch with the present market, so hope to hear some recommendations either from experience, or reviews.
Either of these?
https://www.richersounds.com/tv-projectors/all-tvs/lg-55nano796ne.html
https://www.richersounds.com/tv-projectors/all-tvs/sony-kd55x7052pbu-black.html
Many thanks in advance!
Yeah Peter Tyson is fine.
The Panasonic is an amazing TV though. Sorry didn't check the stock status. Seems it's £700 everywhere else, but you might be able to possibly get them to price match if you did go for it, sure Richer Sounds would do it for that.
Yeah the Panasonic TX58HX800B is much better than the one you linked. Much better processor supports all the 4k formats - HDR10+ / Dolby Vision / HLG. Brighter, deeper blacks etc.
@Simmz Samsung arrived yesterday, all installed, and really couldn't be happier! It is so much better than my old Sony that even my wife noticed, which never happens :p
Thank you for taking the time to help, it's really appreciated
I've turned off all the eco options so far, hoping to get some time to fiddle with it at the weekend
